Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-09-2008, 07:30 PM
fordkev is starting off with a positive reputation.
4.2 to 3.8 swap info
Greetings all,
I am posting this for anyone interested in an inexpensive alternative to replacing a blown 4.2 v6.
I just completed the swap in my 98 f150 4x4 5 spd. This swap is as easy as a rebuilt long block. I used a 3.8 from a 2000 mustang 5 spd. I had to swap intakes and motor mounts, engine wiring harness etc. You have to use the 3.8 flywheel as the bolt pattern on the crank is different, remove the dowl pins and the truck pressure plate bolts right up. A couple things to watch for, if the cam sensor on the new motor is different you have to swap the whole syncronizer. I found out the hard way, swapped the sensors, syncronizer promptly wiped out the sensor, cost $60. Do not put the knock sensor in the block until the motor is in the truck, broke mine off the block, cost $100. Expensive little sucker.
Total cost of the swap, just over $800 including fluids and the parts i broke being a dumb @$$. I suspect you could do it for under $700 if you where careful with everything. Still beats $1600 for a used 4.2
Been driving it for 3 weeks, no engine light, just passed state inspection includeing OBDII test. AS for power i se a slight difference in low end torque but its more than tolereable.
hope this info helps someone
kevin
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-09-2008, 09:11 PM
monckywrench is gaining momentum as a positive member of FTE.monckywrench is gaining momentum as a positive member of FTE.
Slick swap. That engine plus a cheap F150 with a grenaded 4.2 would make an inexpensive but decent ride.
  #3 (permalink)
Old 02-20-2008, 08:31 AM
CIRCLEBFAB is starting off with a positive reputation.
3.8 Swap
Kevin, thanks for posting your swap as I am starting a like swap. I have a 1999 3.8 out of a mustang automatic with 49,000 miles. I am going to put it in my 1997 f-150 with a 4.2 automatic. I would appreciate any more "heads-up" you could give me. Could you tell me if you used the 3.8 injectors or the 4.2's also maybe a little more info on the cam pos. sensor. What does it take to change if I have to? THANKS!!! JIM
  #4 (permalink)
Old 02-20-2008, 08:54 PM
From what I've seen of these on Taurus engines, the cam pos sensor and synchronizer have different diameters where the sensor slides in, and some have different connectors on the sensor itself. Just use the 4.2 assembly. It removes like a distributor.
Pic of what they look like:
http://autorepair.about.com/library/...bl361a-lib.htm
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
