Arkansas Chapter Join Chapter Leader: Kramercd
First ride!!
Old 02-09-2008, 06:14 PM
mudder460's Avatar
mudder460
mudder460 is offline
First ride!!
Just wanted to let you all know I just took Mater around the block for the first time!! Drives good for the most part. Second gear grinds pretty good, the other gears are fine. Just need to change the carrier bearing and u-joints. It is funny to see the truck facing the house for the first time!!!
Old 02-09-2008, 06:39 PM
cookie88's Avatar
cookie88
cookie88 is offline
Haha....cool. Congratulations.
Old 02-09-2008, 06:41 PM
tojoski's Avatar
tojoski
tojoski is offline
Everything go A-OK with your brakes?
Old 02-09-2008, 08:22 PM
mudder460's Avatar
mudder460
Brakes were good good the most part. I was done with the front in like 15min. The passenger rear I made the mistake and took everything off when I didn't need to. So needless to say that took some time to put back together. The driverside rear drum was rusted to the axle, so I had to beat and pry on that one for a while! My neighbor came over so that made the bleeding go fast. I will probably bleed them a little more tomorrow.
Old 02-10-2008, 01:17 AM
1996pwrstrk's Avatar
1996pwrstrk
1996pwrstrk is offline
Thats great Andy did you check the timing ?
Old 02-10-2008, 05:30 PM
mudder460's Avatar
mudder460
I tried to check the timing but everything is covered in goo. I am going to have to clean it up this week and see if I can check it.
Old 02-10-2008, 08:23 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
Congrats on the first ride, it's always fun to see what your project will do.
darickh
1978 - 1996 Big Bronco
26
09-02-2011 05:24 AM
zer0321
09-12-2007 12:54 AM
Motorhead351
16
08-12-2005 09:35 AM
Bimmer ese
20
03-29-2004 08:25 AM
serving_time
15
10-23-2003 03:57 PM
Quick Reply: First ride!!
