Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-18-2000, 08:13 AM
DeenHylton is starting off with a positive reputation.
400 to 460
__________________
1989 F250 460 C-6, RV cam, headers, duals, K&N, shift-kit, now 4.10's.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-24-2000, 02:32 AM
g man is starting off with a positive reputation.
400 to 460
I would like to swap the 460 C6 (15,000 miles)from my 77 F 350 super cab into my 1980 F 350 dually reg cab that currently has a 400 4spd. Would like any info such as -will motor mounts and perches bolt up or what options.-will trans lenght be the same for drive shaft hook up - is the spline the same on tailshaft.- are there oil pan concerns.-will exhaust manifolds fit in with out any problem.- what steering colum will fit pref tilt, 80-86 p\u or Bronco ? I would like to cover all angles before I commence the swap therefore all information will be put to good use.
Thanks Glenn.
  #3 (permalink)
Old 12-24-2000, 08:19 AM
foe6tee is starting off with a positive reputation.
400 to 460
Check out L&L Products,there number is in a previous post in this section.I'm not sure if they are still there,but if they are,they know 460 swaps.I went from 88 windsor in a f350 to 69 429 out of a town car.They had ever thing I needed.Let us know somethin.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
