Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 02-09-2008, 04:39 PM
BOBSDIESEL BOBSDIESEL is offline
Garage is empty, add now
BOBSDIESEL is starting off with a positive reputation.
Exhaust Leak?
I was looking for a fuel leak while my truck was running and noticed that i have exhaust flow coming out of my engine near the turbo. i tracked it down and it looks like it is coming from the turbo pedistal. when looking at the pedistal when its installed there is a rod that goes into the passengers side below the circular exhaust deal thats hooked up to the turbo. i have noticed exhaust the cabin for a while now and never really thought about it. has anyone ever had this problem and what exactly is it that its leaking out of?? thanks
__________________
95 F250 XLT, TYMAR AIS, 3IN DP, 4IN RANCHO LIFT, 35" BFG AT, 341K MILES
  #2 (permalink)
Old 02-09-2008, 04:51 PM
WALJON's Avatar
WALJON WALJON is offline
WALJON is gaining momentum as a positive member of FTE.
Are you noticing any power loss? have you noticed the the smell since you changed the down pipe? could be the down pipe not on properly or it could be the gasket between the exhaust up pipes and the turbo. the thing you are describing is the exhaust back pressure valve control cylinder and that would be leaking oil if anything
__________________
03 dodge 3500 6 speed cummins
98 Expedition EB
  #3 (permalink)
Old 02-10-2008, 08:25 PM
Quote:
Cant really say if i have a power loss. The truck has had so many issues I dont know what its supposed to be like. i physically saw puffs of exhaust somke coming from out of that hole with the rod and it does look like it has or does currently leak a little oil out of that hole. I have checked the DP and the fitting if flush and clamped but I am thinking about getting some copper seal and trying that on th DP as extra security...
__________________
  #4 (permalink)
Old 02-11-2008, 08:49 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
It sounds like the ebpv valve is bad. Especially if yoiu see oil leaking out of it. You can remove it and gut it but there will need to be some welding done to plug some of the holes. tjbeggs has one that is done like that.
__________________
97 F250 Rosewood Stage II.75's, DP Tuner Live Tuned, Modded H2E, Terminated HPOS, Comp 910's, ARP studs, Swamps Pushrods, 6.oh Cooler, BDP elec. reg. return fuel, Valair full feramic clutch, RSK, D60, SD 1 ton springs DRD INMATE # 40
Neal's Pics and H2E install
Tennessee Chapter Leader Join Chapter here
  #5 (permalink)
Old 02-12-2008, 08:58 PM
Quote:
What kind of benefit/loss is there to gutting it? I mean its not going to hurt anything right?
__________________
  #6 (permalink)
Old 02-12-2008, 09:41 PM
Correct but it does impare the flow thru the intake but not much. Those who have it gutted never plan on using it (obviously) and they are fine tuning as much as possible for performance. I would like to do that soon but no hurry.
__________________
  #7 (permalink)
Old 02-13-2008, 04:27 AM
RubberDuck's Avatar
RubberDuck RubberDuck is offline
RubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to all
I'll bet you a dollar that your up pipes are leaking. You would see exactly what you are describing. And it's a very common failure on our trucks. Not to mention, I have the same problem on my new truck. Hope that helps.
__________________
RubberDuck
1995 F350 4x4 CC Dually-ROCKEE
1995 F350 4x4 Reg. Cab Dually-3.0 Puller-BOBBIE'S KITCHEN PASS
  #8 (permalink)
Old 02-13-2008, 06:36 PM
Quote:
Up pipes? do you mean the Y pipe between the heads?
__________________
  #9 (permalink)
Old 02-13-2008, 07:38 PM
WALJON's Avatar
X2
__________________
98 Expedition EB
  #10 (permalink)
Old 02-14-2008, 01:28 AM
RubberDuck's Avatar
No, I mean the pipes that feed the turbo from the back. One pipe comes off each exhaust manifold and turn directly up to the turbo. Where they both meet the turbo, they are sealed with a doughnut gasket and flange. They are very prone to leaking. Powerstroke shop dot com sells them for right at $200. You get new pipes and all. But I don't have the link.
__________________
RubberDuck
  #11 (permalink)
Old 02-15-2008, 09:50 PM
Anyone have a pic or a link of the up pipe so I can see what were talking bout?
ugggg another fuel leak
__________________
  #12 (permalink)
Old 02-15-2008, 09:59 PM
WALJON's Avatar
Hi Bob I don,t have a pic but if you are looking at the turbo just behind it there is a square piece with four bolts this is where the up pipes bolt to rite behind the exhaust side of the turbo if you can,t see it jump up on the bumper and look rite in there behind the turbo
hope that makes sense lol
WALTER
__________________
98 Expedition EB
  #13 (permalink)
Old 02-17-2008, 09:46 PM
if one was to got about gutting the EBV how would i do it?
__________________
Tags
1997, 2001, 73l, diesel, donut, exhaust, f250, ford, gasket, leak, leaking, leaks, oil, turbo, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
