Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-09-2008, 05:01 PM
DR Smith is starting off with a positive reputation.
Question front fender question
the brace that goes on the lower front of the front fender bolts where on the truck? Mine are missing and when I put the fenders on today I see there are places on the fender to bolt them up,but not sure where the other end goes,
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-09-2008, 07:25 PM
bigwin56f100's Avatar
bigwin56f100 is starting off with a positive reputation.
It bolts up to the front air deflector/front pan. I believe its the middle bolt hole. I cant say for sure with out looking though.
Kevin Bigwin
__________________
1956 Custom Cab Big Window. 272 Y block 3sp. See gallery. Kevin
  #3 (permalink)
Old 02-09-2008, 09:00 PM
cmoritz is starting off with a positive reputation.
Don't mean to hijack this question.,butalong the same line..How about the REAR brace, I know it bolts to the fender .., but how about the other end??? Does it bolt to the Bedwood???
  #4 (permalink)
Old 02-09-2008, 10:30 PM
53pickemuptruck is starting off with a positive reputation.
Yep. It goes on the bottom side of the bed.
  #5 (permalink)
Old 02-10-2008, 10:56 AM
bobj49f2's Avatar
bobj49f2 is gaining momentum as a positive member of FTE.bobj49f2 is gaining momentum as a positive member of FTE.
Hope this helps:
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--
49 F-2 pickup
48 F-1 panel truck
49 F-1 panel truck (half apart/together)
49 8N tractor
48/51 F-4 flatbed (2 in 1)
My web site
  #6 (permalink)
Old 02-10-2008, 11:06 AM
bobj49f2 , Thanks! That's the 1st time I've ever seen that PIC , Never noticed/knew about those two struts..8270,8271...inside the fenderwell.
Makes me rethink the opening thread.
Everybody else installing these??...they were not in my parts pile.
Just goes to show , You learn something new everyday!!!
  #7 (permalink)
Old 02-10-2008, 04:24 PM
fking1's Avatar
fking1 is starting off with a positive reputation.
My 55 has only the 16010/11 and that is all. It was all original when I bought it.
  #8 (permalink)
Old 02-11-2008, 09:30 AM
Ditto on the 16010/11. Not sure which truck had those other bars. Maybe those are the ones crossed in the radiator saddle. Pick up a catalog from Mid-Fifty they have a lot of good breakdown pictures and tips about parts in it.
  #9 (permalink)
Old 02-11-2008, 10:19 AM
AXracer's Avatar
AXracer is gaining momentum as a positive member of FTE.AXracer is gaining momentum as a positive member of FTE.
I wondered the same thing about the 8271, 8272 bars the first time I saw that pic, but I haven't found anyone who has them on their truck. May have been deleted in a last minute production change after the illustration was made? The crossed bars were riveted in place on the radiator saddle. The other end of 16011 and 12 goes to one of the bolts that attach the inner fender to the air deflector, it should be pretty obvious which one.
__________________
Passionate about autocross racing!
2003 GSL, 2005 HSL National Champion
1956 F100 Panel support/tow vehicle
2007 Solstice GXP
2002 Celica GT 2003 GSL National Champion
1999 Miata gone but not forgotten
  #10 (permalink)
Old 02-11-2008, 07:29 PM
56panelford's Avatar
56panelford is starting off with a positive reputation.
Quote:
It's the first I seen of these braces as well, but seeing as you (AX) have mentioned the the cross bars on the radiator saddle is there any way of shortening those bars the one I have seem to be too long and the saddle seems to be fine, the rad bolts in and the holes line up, was wondering if they could be heated and shrunk some how?
Sorry for the hijack
  #11 (permalink)
Old 02-11-2008, 08:39 PM
AXracer's Avatar
They bow outwards to crisscross and I'd guess to give a little flexibility. Why would you want to straighten them?
__________________
2007 Solstice GXP
  #12 (permalink)
Old 02-11-2008, 10:00 PM
There is one of them that seems to be much longer than the other, may have been that way from the factory but just seems odd. I don't think you would see it that well behind the grill. I think that I'm more curious to know if the heat and quench method would work on a steel bar or not. Just a willingness to learn some more I guess.
  #13 (permalink)
Old 02-12-2008, 01:04 AM
AXracer's Avatar
No, you cannot shrink a bar like sheet metal. You would need to cut and weld to shorten it. Have yours been removed from the radiator support? I removed mine and put bolt on tabs on them so I could install my AC condensor behind them. They are needed to keep the support from wracking and damaging the radiator.
__________________
2007 Solstice GXP
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
