Problems with Wiland Stealth intake with Holley 750 cfm 4160 carb
Has anyone else had a problem with the fast idle adjustment screw scrapping the side of the manifold? I ground the side of the manifold down so it doesn't do it anymore. I was just wanted to know if I am hooking it up wrong or if there is some sort of defect? Thank you for your help.
I know a lot of FE manifolds won't fit four barrel carb without using a thicker carb spacer/gasket. My 460 has a Holley 4bbl with the factory intake and factory spacer. The carb won't operate properly, the linkages hit the manifold.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
__________________
Jason Kendrick
'70 F100 Custom 390/C6
'93 Mercury Topaz 2.3L
'99 Ford Windstar SEL
