Tips on replacing belt...
Get a Motorcraft serp, but the Gators are good too.
No special tricks, just get good leverage on the idler and you should be okay.
I usually use a cheater bar on a 1/2 rachet for maximum performance.
Thread the lower pulleys first and leave the closest one to you as the last one to be installed.
Presuming its the same setup as the '98 I'm familiar with, please note that there is both a TENSIONER pulley & a "idler" pulley. You must "get good leverage on the" TENSIONER pulley arm in order to compress the spring & remove the belt. The "idler" is fixed & just gets threaded, study the belt route diagram.
Its a stiff spring & solo can be a challenge. A helper to hold the tensioner back is a great assist, even with a "cheater bar". A new belt can be stiff & have folds that fight you. I use a ratchet handle extension made out of SS boat railing tube to gain loads of leverage.
These belts routinely last 100K & the different brands are very close in longevity & slippage. There's probably more range of difference in price than performance. I usually shop for parts like insurance estimates & get 3 quotes. Its almost comical how often & widely prices can vary for the same item. I've also noticed times when the seemingly best part may also be the lowest price! Sometimes saving a few bucks & taking a shorter ride rules. Occasionally you strike out & have to get the only part in town that day. When I shopped for a serp belt in Sept prices varied from $24 to nearly $50 & Nobody had GatorBack in stock. Also, the so called 'experts' were wrong, the terrible noise was not 'just the belt'.
In the case of my '98 it was None of the Above.
The so called 'experts' completely missed the cause of the chirping at idle & loud shreeking upon acceleration. I discovered that the harmonic balancer had squirmed out of line resulting in a minor misalignment with the AC pulley.
Originally Posted by superdutymj
It seldom ever is! Usually it'll be idler pulleys, tensioners, and or fan clutches too! Nevermind the rest of the accessories that have bearings too!
Big Skier
31
02-27-2019 07:21 AM
Headviking
20
03-08-2015 09:00 AM
courtneylaw
02-25-2014 03:49 PM
