5.4 oil capacity
Originally Posted by crazeee-eyes
I work at Team Ford ( Las Vegas ) we put 7.3 qts , to the top of the stick. 04 to present 5.4 3V engines.
dam, i buy valvoline 5-30 full synth by the case
(6 quarts) and it took 7. bastids
Matt
Its a consiracy between ford and oil companies. Kinda like the hot dog companies and the hot dog bun companies. (10 dogs per package, 8 buns per package)
6 quarts doesn't even touch the "safe Zone". I end up puting 7 quarts in and adding a Quart at about the 2000 mile mark. Oil disapears (no oil in driveway, no smoke) where it goes is any one's guess.
Matt
Here's something you will encounter with piston aviation engines. The dipsticks will show full at say 8 qts. So you change the oil and filter and top it off at 8 qts. A couple hours of flying and it's down to 6.5 and it will stay in the safe zone for many hours more. After a while you learn to just top it off at 6.5 instead of the 8 since the other quart and a half are blown out. Some engines are worse than others at this but they all function very well when not topped off with oil. If you sleep better with the dipstick reading full, ok. Your engine can't read the dipstick though and only knows when there is too much crankcase pressure or there is foaming from the crank splashing the oil.
One of the planes I fly will hold 12 qts but that would be a waste since it just blows it out. It runs very well at 9 and can be ran all the way down to 4. When the stick says it's at 8, I add a quart to make it 9.
