5.4 oil capacity - Ford Truck Enthusiasts Forums
5.4 oil capacity
Old 02-09-2008, 03:06 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to behold
5.4 oil capacity
doesnt the 5.4 take 6 quarts? i put 6 in and its still low on my dipstick.
Matt
Old 02-09-2008, 04:05 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
That's normal Matt. There have been some heated discussions in the past about it. Some swear by the dipstick others by the engineers who say 6 qts is all you need. I put 6 in mine and don't worry about it.
Old 02-09-2008, 08:04 PM
xtrford xtrford is offline
xtrford is gaining momentum as a positive member of FTE.
I agree, some people get way too bent out of shape if the oil level isn't at the very top of the dipstick.
Old 02-09-2008, 08:16 PM
crazeee-eyes crazeee-eyes is offline
crazeee-eyes is starting off with a positive reputation.
I work at Team Ford ( Las Vegas ) we put 7.3 qts , to the top of the stick. 04 to present 5.4 3V engines.
Old 02-09-2008, 08:42 PM
superdutymj's Avatar
superdutymj superdutymj is offline
superdutymj is starting off with a positive reputation.
Quote:
Wow thats significantly higher than recommended! i wouldn't recommend anything more than the 6 quarts, as too much oil can be just as bad as too little. the crank'll whip up the oil into a froth that the pump can't circulate and you still end up with oil starvation, especially in the heads.
Old 02-09-2008, 10:23 PM
Quote:
That is spot on.
Old 02-09-2008, 10:36 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I go by the dipstick, thats what it is there for. Mine takes around 7qts and has over 200K trouble free miles. A universally arbitrary number in a manual is not going to tell me what every single 5.4L's capacity is.
Old 02-09-2008, 10:39 PM
What GALAXIE641 said.
Old 02-10-2008, 03:20 AM
fordboy_52's Avatar
dam, i buy valvoline 5-30 full synth by the case
(6 quarts) and it took 7. bastids
Matt
Old 02-10-2008, 12:51 PM
golddirt golddirt is offline
golddirt is starting off with a positive reputation.
99 5.4 requires 6 quarts this is in the safe zone. mine requires 6.5 to reach max
Old 02-10-2008, 01:50 PM
6.5 qts is correct for early 5.4 L We put 6.3 qts ( to the middle of the stick )
Old 02-10-2008, 03:25 PM
2002 F-150 FX4 2002 F-150 FX4 is offline
2002 F-150 FX4 is starting off with a positive reputation.
Matt
Its a consiracy between ford and oil companies. Kinda like the hot dog companies and the hot dog bun companies. (10 dogs per package, 8 buns per package)
6 quarts doesn't even touch the "safe Zone". I end up puting 7 quarts in and adding a Quart at about the 2000 mile mark. Oil disapears (no oil in driveway, no smoke) where it goes is any one's guess.
Old 02-10-2008, 08:33 PM
kingrat427 kingrat427 is offline
kingrat427 is starting off with a positive reputation.
i have a 2000 f150 7700 series with a 5.4 and it takes about 7.5 qts
Old 02-10-2008, 08:45 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
The 5.4 in 2wd trucks takes 6 and in 4x4 trucks it takes 7. The pans are different.
Old 02-10-2008, 08:52 PM
Here's something you will encounter with piston aviation engines. The dipsticks will show full at say 8 qts. So you change the oil and filter and top it off at 8 qts. A couple hours of flying and it's down to 6.5 and it will stay in the safe zone for many hours more. After a while you learn to just top it off at 6.5 instead of the 8 since the other quart and a half are blown out. Some engines are worse than others at this but they all function very well when not topped off with oil. If you sleep better with the dipstick reading full, ok. Your engine can't read the dipstick though and only knows when there is too much crankcase pressure or there is foaming from the crank splashing the oil.
One of the planes I fly will hold 12 qts but that would be a waste since it just blows it out. It runs very well at 9 and can be ran all the way down to 4. When the stick says it's at 8, I add a quart to make it 9.
O2 sensor causing lean code ? mattymax 1999 to 2016 Super Duty 9 12-20-2015 10:13 PM
Stock Alternator Amps ? 08' F-350 mattymax 1999 to 2016 Super Duty 1 12-07-2015 12:41 PM
Changing belt and tensioner 5.4 mattymax 1999 to 2016 Super Duty 5 11-08-2015 05:57 PM
Newer Engine Matt 68 F100 1967 - 1972 F-100 & Larger F-Series Trucks 7 09-22-2015 05:50 AM
2008 5.4 Diesel Sound mattymax 1999 to 2016 Super Duty 7 08-04-2015 01:23 PM
Tags
1997, 2000, 2006, 54, 98, capacity, capcity, crankcase, engine, f150, ford, oil, recomended, triton, v6, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
