5.4 oil capacity
Originally Posted by fordboy_52
all i know is, i was pissed when i pulled my oil cap and a brown sludge was affixed to my oil cap. i have around 20k left on my warentee. i wonder if i should clean the motor out. get it done before i expire
Matt
Matt
5.4 Fluid Capacity
Has anyone ever tried running an engine with way too much oil in it? Perhaps you have. What happens? If the engine does not smoke profusely because of oil leaking past the rings, then you get an engine vibration, and poor fuel economy. If you don't beleive me try putting 14 quarts of oil in a 2004 5.4 triton. I know I have done it. The hese undesireable affects are because with a higher than normal amounts of fluid inside a crankcase there is less room for air, which causes increased crankcase pressure. The pressure rises because fluids do NOT compress...pascal's law.
Inside the 5.4 triton V8 and the 4.6 triton V8 the parts are basically the same, subtle differences, except for one thing, the stroke is longer on the 5.4. It a taller block. The longer stroke in the block makes for more air space between the top and bottom of the bore. Hence a 5.4 has more air inside the crankcase than a 4.6.
If you put more oil in an engine you eliminate some of the air. This raises the crankcase pressure and can result in losses of fuel economy and performance... undesireable.
Putting more than 7 quarts is asking for trouble. If you are somewhere between 6 and 7 you should be fine on a 5.4, but all you really need is 6. I have worked at a Ford dealership, there we put 7 in all 5.4's and 6 in all 4.6's.
I always have driven my 5.4 with 7 in it and never had a problem. I am going to try switching to 6 and see if I can get any better gas mileage.
Thank you
-Adrien
