9" rear end
9" rear end
I need advice on what disc brake set-up to go to . I started with a 1977 lincoln rear set up for disc brakes that are now obslete( can't find banjo bolts) I either keep looking for those or start from the axel plate with a new bracket, caliper, discs etc. any ideas?
After this is solved I have another 8 or 10hrs before I add gas after a 9 year build.
1956 f100
1956 f100
Take a look ot this old post of mine
https://www.ford-trucks.com/forums/6...onversion.html
I posted all the part numbers you'll need for a large bearing disc brake setup.
