Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-09-2008, 03:35 PM
cool 48's Avatar
cool 48 is starting off with a positive reputation.
You Tube whitewalls put to the test
Hey guys. Ever found yourself looking for ideas about whitewalls , because of the lack of funds for $900 Cokers? That is exactly where I am. I realise it is a supply and demand world we live in, but it doesn't cost any more to make coker wide whitewall tires , than it does a tire. Anyway, I am sure you have all seen the You Tube video of the guy taking a simple whit wall tire and making a wide whitewall out of it. I wanted to see how it really looked in person. So, I went to my local tire store that I always deal with, and they gave me an old crappy tire to experiment with. Now remember , I used a simple grinding disc that was brand new ,and not rounded yet at the edges. I feel that would help in taking lighter passes at the black portion of the tire. I took photos of the tire the way I got it, and 2 more after I did my thing to it. I gotta tell you, it turned out a heck of alot better than I thought it would. I spent 34 minutes on this little experiment,and I was pleased with the results. I am sure if you look close , you can see some flaws. But this was just a test. Doing this does not take long,and it is very affordable to do. There is only one drawback. You have to find 4 tires with whitewalls to do this to. And you want them to match. Now, for you guys restoring trucks to original,and the purists here on this site, I'm sure this is not something you want to do. But, for you guys who have one in college,and two more on the way, you might want to take a look. That is , if you are not putting the tires on a $20k ride.I put a caliper on the tire to measure thickness before and after. Such a small difference ,I could not see or feel any structural difference in before and after. But , I guess judge for yourself.
I think I will call these "Diet Cokers"
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-09-2008, 03:39 PM
tankrsc is starting off with a positive reputation.
Not seeing the pics? went to gallery but the pic is X'd out
__________________
  #3 (permalink)
Old 02-09-2008, 03:41 PM
bobj49f2's Avatar
bobj49f2 is gaining momentum as a positive member of FTE.bobj49f2 is gaining momentum as a positive member of FTE.
Where's da pictures? I gotsa have pictures!!!
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--
49 F-2 pickup
48 F-1 panel truck
49 F-1 panel truck (half apart/together)
49 8N tractor
48/51 F-4 flatbed (2 in 1)
My web site
  #4 (permalink)
Old 02-09-2008, 03:47 PM
cool 48's Avatar
Well, I'm trying to post em right now. ; ; What the #$@!%^#!!They are in my gallery. The whitewall is not real wide, but it iwas just an experiment.
  #5 (permalink)
Old 02-09-2008, 03:56 PM
cool 48's Avatar
What it turned out to look like
Diet Coker
  #6 (permalink)
Old 02-09-2008, 03:58 PM
cool 48's Avatar
When I got it from the tire store.
  #7 (permalink)
Old 02-09-2008, 04:05 PM
cool 48's Avatar
If you guys are wondering why it is only 1 3/4" wide and not 2 1/2", it is because I am not using this tire for anything. Once I get the tires I want, I will make them just 2" . It is good to find tires that have a thin line around it. Most tires will have lines on them. Then you can choose which width you want.
  #8 (permalink)
Old 02-09-2008, 04:13 PM
4tl8ford's Avatar
4tl8ford is gaining momentum as a positive member of FTE.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1997 Ford Explorer
http://www.4TL8Ford.com
1/20/2009
End of an Error
  #9 (permalink)
Old 02-09-2008, 04:48 PM
restoringmy46 is starting off with a positive reputation.
I saw a guy at a car show in Oct. that had a grinder or something made on the end of a grinder to make white walls bigger or make your own. He took a blackwall tire and was make flames on the side of it. I would like to try my hand at doing that.
Scott B.
  #10 (permalink)
Old 02-09-2008, 04:51 PM
cool 48's Avatar
Just go to the tire store that you deal with. I'm sure they would let you rummage tghrough their tire stack for a suitable whitewall.
  #11 (permalink)
Old 02-09-2008, 05:45 PM
Looks good may have to try that for what I don't know I reckon just to say I did it You just used a grinding disc on like a 4-in angle grinder? I have not seen the you tube thing so if anyone has a link?
__________________
  #12 (permalink)
Old 02-09-2008, 06:09 PM
cool 48's Avatar
Yes, but try to use a good used grinding disc. One that has been used on steel before. The reason I say that, id a new one is very square on the edges.It makes it a little harder to grind it smooth. But , that is what I used. Once I did all the rough cutting, I then used a palm sander and 80 grit sanding discs. You can buy everything you need at TSC. It really came out better than I thought. Just take your time, and don't try to take too much at one time. Also , just as the same as steel, make longer passes in a sweeping motion. That will cut down on the gouges and such.
  #13 (permalink)
Old 02-09-2008, 08:30 PM
CIAF's Avatar
CIAF is starting off with a positive reputation.
There is a specific grinding disc that is used on an air grinder to scuff the inside if tire prior to applying a patch. It normally has a 1/4" arbor hole and is used with a small air motor that looks like a fat die grinder. This tool looks like a small bowl and is made of formed metal and has thousands of abrasive bits attached to it and is copper or gold in color. It is really ideal for rubber grinding and will not load up. It is available at tire shop suppliers. Your friendly tire store may show one to you. Now if a guy were to set one up to spin up, while a mounted tire were spinning down, it would be like 1970 when I saw this done. But, if a guy were friendly with a recapper, then he could just put the tire on the carcass lathe, and move said buffer to the side instead of the top and corner. Yes, I did work at a capper doing Bandag's all day. Yuk.........
__________________
56' F-100 Mild Custom 3 year test build. Done/Never Done.
Did someone say COOKIES ??
  #14 (permalink)
Old 02-09-2008, 09:46 PM
cool 48's Avatar
Yes, as soon as I get my tires ,I am getting that bowl shaped tool you speak of. I worked for a truck stop when I was a kid, and that's what we used also to rough up the inside of a tire before patching it. I have a 1/4" air die grinder I plan on using.
  #15 (permalink)
Old 02-10-2008, 09:22 AM
economan is starting off with a positive reputation.
a feller here in town did the ol' grinder trick to his 59 custom royal but he was fortunate to have a son in law or some relation like that who worked in a tire factory to tell him what model of tire had the largest white insert so's he knew what tires to buy in the 1st place. i'm thinkin someday when i can afford to get a full set of new matching tires for my panel i'll be doin' the whitewall thing till then i'll continue rollin' around on the tires i got free from work @ the dealership.......... used to score the unused spare tires offa abused trade in work trucks we didn't want to resell to our customers & put ol' skins on em before they went to the auction. (heh heh)
mikie
near ottawa canada
58 merc 100 panel - 64 econoline p/u
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
