Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 02-10-2008, 11:19 AM
bobj49f2's Avatar
bobj49f2 is gaining momentum as a positive member of FTE.bobj49f2 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by CIAF
... Now if a guy were to set one up to spin up, while a mounted tire were spinning down, it would be like 1970 when I saw this done.....
I've been thinking of doing this for a while. I saved a rear axle from a parts truck I had and I have a Rigid pipe threader. I was going to chuck the axle in the threading machine and bolt the wheel to it. The threading machine will spin at a constant speed while using the grinder. I also want to try painting a white wall on the side of tire. Not that I think it's a better way to do it, I just want to see how it turns out and how it lasts.
Quote:
Originally Posted by tankrsc
Looks good may have to try that for what I don't know I reckon just to say I did it You just used a grinding disc on like a 4-in angle grinder? I have not seen the you tube thing so if anyone has a link?
Here's the Youtube link:
http://youtube.com/watch?v=xkcm3rh60p0
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--
49 F-2 pickup
48 F-1 panel truck
49 F-1 panel truck (half apart/together)
49 8N tractor
48/51 F-4 flatbed (2 in 1)
My web site
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 02-10-2008, 11:54 AM
OldgreenF1's Avatar
OldgreenF1 is starting off with a positive reputation.
Bob,
I was thinking of something along the same lines.
IM putting a mounted tire on an axle and making a stand for a cutter off a lathe and will turn the tire by hand letting the cutter make a clean edge and then using a grinder or angle grinder to clean the center out.
  #18 (permalink)
Old 02-10-2008, 12:17 PM
cool 48's Avatar
cool 48 is starting off with a positive reputation.
From what I hear , the Michelins are the worst ones to do this to.
  #19 (permalink)
Old 02-10-2008, 03:52 PM
kdmcinnes's Avatar
kdmcinnes is starting off with a positive reputation.
this is a simple thing that Rodgers have been doing for a while, the do look ok but I do know a few people who have done this on there rat rods and the have the side walls blow out after they have been on. They seem to think that I weekend the side walls. To each is own but all I can say is be carefully saving a couple hundred isn't worth your life. Be safe.
Kyle
__________________
This is not a hobbie, It's a lifestyle!
  #20 (permalink)
Old 02-10-2008, 04:35 PM
cool 48's Avatar
I believe the only way to weaken the sidewall , is to cut into the actual belts themselves. You have to go pretty far to do that. When grinding the black to expose the white, you are taking a thickness of rubber that is about as thick as a sheet of notebook paper. The white under the black is only about 1/16" thick, so if you go deep enough to damage the integrity of the tire, you have also messed up a good white wall. But , I do understand what you are saying about safety though.It is always better to just go down and buy a set of cokers. But , again , if you are real careful , you can have a set of what I like to call a set of "Diet Cokers" . .... Ok that was a stretch, but it is a little funny.
  #21 (permalink)
Old 02-10-2008, 05:30 PM
CIAF's Avatar
CIAF is starting off with a positive reputation.
Quote:
Originally Posted by OldgreenF1
Bob,
Seen it done alot. It works well. Some guys even buy old wheel balancers with out the electronics just to use as a spinner. This allows the tire to be mounted and grinds better with air in it. Then you could use a woodcutters tool and shave it off in about 2 minutes each. You would just need a small stand to hold the tool in place just like on a shopsmith. This is how it is done way down south...WAY Way down south.......
Jon
__________________
56' F-100 Mild Custom 3 year test build. Done/Never Done.
Did someone say COOKIES ??
  #22 (permalink)
Old 02-11-2008, 09:12 AM
bobbytnm's Avatar
Roast em' if you got 'em
bobbytnm is gaining momentum as a positive member of FTE.bobbytnm is gaining momentum as a positive member of FTE.
As a kid I remember seeing whitewall being cut in and/or widened. I used to go with my dad to the tire store and it was a fairly common practice. They would chuck up the tire on a machine and cut yuour whitewall to the width you wanted.
Great info in this thread!
thanks
Bobby
__________________
...Someday our foes may win...
...but NOT today!!
1949 F1, 500ci Caddy
1959 Dodge D100
1965 Falcon
1994 Harley Road King
  #23 (permalink)
Old 02-11-2008, 09:55 AM
cool 48's Avatar
Well, I can tell you one thing. This beats the heck out of the tire paint that is being sold. In some cases I have heard it works well. But, I think most of the time folks don't know how to properly prep a tire for this type of paint. And it is just a temporary thing.
  #24 (permalink)
Old 02-11-2008, 04:29 PM
CIAF's Avatar
And the tire paint really was intended for painting over a whitewall to renew it, not for making a WW from a blackwall. Some guys just thought " hey, what if ?" and went for it. After sales slowed, the marking gurus tried to revive sales by pitching it as a paint to turn a BW into a WW. Seems some ate it up. Just makes a poor guy look even poorer and rather hokey IMO. But, to each their own.
Jon
__________________
  #25 (permalink)
Old 02-11-2008, 07:40 PM
jniolon's Avatar
prone to instability
jniolon has a good reputation on FTE.jniolon has a good reputation on FTE.
well, back in my day... if we couldn't afford white walls... you could buy 'porta walls' ...a round flat insert with the applicable white ring that mounted on the tire and was held on by the bead...
Western Auto used to sell a bunch of them... and they lasted through several tires...
porta walls
but I do remember some discussion about them not working well with radial tires... because the radials flex more in the side walls and the inserts will cut a groove in the sidewall of the tire... hardly seems plausible to me... but what I heard...
j
__________________
Any day above ground... is a GOOD day !!!
  #26 (permalink)
Old 02-11-2008, 07:52 PM
56panelford's Avatar
56panelford is starting off with a positive reputation.
http://www.youtube.com/watch?v=xkcm3rh60p0
I believe this is the link
  #27 (permalink)
Old 02-11-2008, 08:04 PM
http://www.youtube.com/watch?v=3EvK7...eature=relatedOr you could try this
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
