460 conv.
460 conv.
I heard that u had to change to a transfer case that mounts to an automatic if you change from a stick. Something to do with the splines being different. Just checkin to make sure. I'm also doin a 460 swap. in my 78 f150. It also has a 400 with a 4 speed manual, but i want to go with the c6. If you hear any helpful hints please share them, thanx.
460 conv.
The only change I am aware of that you would have to make to the transfer case is where it mounts. There are two sets of holes on the side of the frame where the mount bolts to, one is used for an auto, and the other for the stickshift. This is for the NP205, if you have the NP203 I believe the mounts are different and this may not apply. Good luck.
Eric Tobolski
Eric Tobolski
Kyle Wood
10-19-2016 11:28 PM
olivedad51
04-05-2016 11:27 AM
