'96 F350 Add-a-leaf kit - Page 2 - Ford Truck Enthusiasts Forums
Old 02-10-2008, 10:39 PM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
Interesting TJ. Do you think the price is right for that add-leaf that is offered on Ebay? Sounds like a pretty good deal to me.
Old 02-11-2008, 08:30 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
yep thats actually a little less than what I paid for the same product 3 years ago.
Old 02-12-2008, 01:21 PM
ToughBuiltFord ToughBuiltFord is offline
FTE Sponsor
ToughBuiltFord is starting off with a positive reputation.
Quote:
Originally Posted by FARM69
You guys have any links as to the right set of add-a-leafs to get for the 250. Also, how hard is install? I'm assuming it probably depends on how rusty things are.
http://motorhaven.autoanything.com/suspension-systems/61A2637A0A0.aspx
Old 06-05-2013, 11:47 AM
nossliw's Avatar
nossliw nossliw is offline
nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.
I know I'm resurrecting this thread. I was just curious if you had to replace your U bolts up front. I'm finishing up a front bumper that currently weighs about 310lbs and putting a Warn 16.5 TI on top of that which is another 138, plus rhino lining weight... I was hoping these would be enough for the additional weight, and just wanted to reuse the old u bolts if possible...
Thanks you guys!
Old 06-05-2013, 01:02 PM
97-psd's Avatar
97-psd 97-psd is offline
97-psd is gaining momentum as a positive member of FTE.
wow, you did resurrect an oldie, I am prety sure we just reused the old u-bolts I would keep an active eye on your ball joints since you are adding so much weight up front
Old 06-05-2013, 02:39 PM
nossliw's Avatar
I completely agree with your statement, I keep an eye on them and these are factory originals on the 350 with 130k on them. I will be doing them this winter with a new pinion seal. The one on my 250 with a D60 SAS has been on there now for about 5 years. It weighs about 90lbs less, so I think I'll be all right for 5 years or so, and I don't mind doing them on those intervals... I appreciate the words and its good to know I can re-use them!
Add-A-Leaf kits? Jacob Bush 1999 - 2003 7.3L Power Stroke Diesel 7 08-06-2015 03:27 PM
Rear leafs Troy_455 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 07-30-2015 05:02 AM
are all lift kits the same? 86fsbronco 1978 - 1996 Big Bronco 7 04-30-2015 11:18 AM
cheap lifts for 04 excursion clvsell3 Excursion - King of SUVs 5 04-27-2014 10:03 PM
rougher ride - add-a-leaf or X-springs sandman3510 1999 to 2016 Super Duty 14 08-09-2009 11:52 PM
Tags
350, 8098, 96, add, alignment, end, f250, f350, ford, front, install, kit, leaf, leveling, lift, powerstroke, shims, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
