Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > New Hampshire Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New Hampshire Chapter Join Chapter Leader: 7283-F250
  #1 (permalink)
Old 02-09-2008, 11:59 AM
thedaddycat thedaddycat is offline
Garage is empty, add now
thedaddycat is gaining momentum as a positive member of FTE.
Another step forward...
Well guys, I made some progress today. I have a '54 Willys Wagon that I bought for $500 and I started to play with it the other week. I had replaced the battery in my Crown Vic and the old one fit in the Willys. Using a jumper I got it to crank. I pulled a 12 volt coil off a garden tractor and bolted it in next to the 6 volt coil, moved the col wire over and tried it.
After filing the points and fiddling with it for a bit I got spark. A slosh of gas down the carb and a shot of ether and it fired up!!! Guess I have a new toy to mess with....
__________________
'03 F-350 XLT 6.0 PSD SRW SC SB FX4
Dieselsite coolant & tranny filters, Bright Box,
22" wipers, M-H FD RD Tranny covers, Fluidamper, leveling kit
TAG, Power Elbow, Blisteins, gages, MBRP 4" Turbo-back
XCal2 by SDT, HFCM drain, Centrimatic balancers
ESP luber, Oilguard bypass filter
  #2 (permalink)
Old 02-09-2008, 12:17 PM
BIGKEN's Avatar
BIGKEN BIGKEN is offline
So Little To Say!!!
BIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputation
Well...you know what they say..."He who dies with the most toys...wins"!!!
  #3 (permalink)
Old 02-10-2008, 03:19 PM
c4barnes c4barnes is offline
c4barnes is gaining momentum as a positive member of FTE.c4barnes is gaining momentum as a positive member of FTE.
Those are so cool. I've always wondered how they'd be with a 4bt, but as this thread indicates, it'd probably be too much for the undercarriage. They swapped it onto a J20 frame.
  #4 (permalink)
Old 02-10-2008, 05:59 PM
I had given a passing thought to the 4BT, weight would be a major concern though. Then I thought about maybe a 3BT or perhaps a 1.6 or 1.9 VW diesel, something lighter. I'm not sure if the small three cylinder diesel tractor engines would have the oomph to get up to highway speeds. For now I'll just play with it as is, maybe wheel it a little and then restore it to "Parade Princess" status.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
