dana 70 vs. 10.25" ford??? - Ford Truck Enthusiasts Forums
Old 02-09-2008, 02:49 AM
mustanginca's Avatar
mustanginca mustanginca is offline
mustanginca is starting off with a positive reputation.
I've been looking to do a solid front axle swap on my F-250 93'. I found a dana 60 front high pinion and a dana 70 rear from an 87' both for $1500. Is a dana 70 stronger than my 10.25"? Or should I just spend the $1500 on a better or newer dana 60? Thanks.
Old 02-09-2008, 07:33 AM
rbloodhound's Avatar
rbloodhound rbloodhound is offline
rbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud of
Hope this helps. I found it on another website. It is a good write up.
Ford 8.8 Rear Axle
Pros
It's Under There Already
VSS/ABS Models
Cons
5 lug, 1/2 ton, Semi-Floater
C-Clips
Weak Carrier Bearing Caps
Weak Housings
Ford 9" Rear Axle
Pros
Common
Tons of Aftermarket Parts
Ground Clearance
Full-Floater Conversions
Indestructable (If You Have the Cash)
Cons
5 lug, 1/2 Ton, Semi-Floater
No VSS/ABS
Low Pinion
See "If You Have the Cash"
Dana 60 Rear End
Pros
Some 35 spline
Good Aftermarket
Decent Ground Clearance
Rare VSS Models
Cons
Some 16 Spline
Most Non VSS/ABS
3/4 ton? 1 ton? Who the Hell Knows
Dana 70 Rear End
If you want a 1-ton axle, but don't need VSS, and loathe GM, this axle is for you.
Pros
Fairly Common
Cheap
Bulletproof In Stock Form
Cons
No Spool
Poor Ground Clearance
Non VSS/ABS
Visteon Sterling 10.25
If you want a 1-ton axle, and you need VSS, this axle is for you.
Pros
VSS Compatable in '87+ (with speedo re-calc)
90% Bolt In
Ford PN F4TZ-1177-C Fixes Pre-'94 Axle Seal Problem
Cons
Weak Pinion Threads
Axle Seals Leak
Some Limited Gear Ratios, No Spool
Expensive
Corporate 14 Bolt
If you want a 1-ton axle, don't need VSS, and don't care about "brand loyalty", this axle is for you.
Pros
Dirt Cheap
Cheap Detroits
Can Shave Pumpkin
Some Stock Detroits and 4.11 or 4.56s Gears
Cons
No VSS/ABS
No Spools or ARB
Some Semi-Float Versions
Massive Pumpkin
*gasp!* It's GM
Ford 10.25" vs. DANA 60 TURBO Clutch, Transmission, Differential, Axle & Transfer Case 8 09-29-2016 01:44 AM
dana 70-sterling 10.25 gears? badasssapper67 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-09-2016 03:05 PM
need help ASAP dana 60 or 10.25 ColdForge 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 08-12-2011 07:26 PM
10.25 or Dana 60??? highrisk 1987 - 1996 F150 & Larger F-Series Trucks 7 11-24-2006 01:36 PM
Dana 60/70/Sterling 10.25 rear axle swap orange78oval 1978 - 1996 Big Bronco 1 01-25-2004 09:11 AM
Tags
1025, 2001, 60, 70, axle, dana, ford, pinion, rear, recalc, replacement, seal, speedo, sterling, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
