Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-09-2008, 12:34 AM
toddinav is starting off with a positive reputation.
No Tail or instrument panel lights
1987 Bronco11 2.9 4x4
Fuse keeps blowing when I turn on the headlight switch. Headlights work fine, its the dash lights and rear tail running lights that keep blowing a fuse. I bypassed the fuel relay switch also 4 months ago, so i have it toggled to my fuel pump (Its the only way i can get it to run) Any help would be apreciated
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-09-2008, 03:37 PM
SShank42's Avatar
SShank42 is starting off with a positive reputation.
I had same problem. Mine was a wire at the rear of the vehichle that was rubbed thru and shorting out.
  #3 (permalink)
Old 02-09-2008, 07:38 PM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
Look under the driver's side lamp ? and make sure the ground is still there.
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
  #4 (permalink)
Old 02-10-2008, 10:26 AM
SShank42's Avatar
Headlight switch could also be a suspect.
  #5 (permalink)
Old 02-10-2008, 10:18 PM
my72ford is starting off with a positive reputation.
i had the same problem on my 86...turned out to be the headlight switch..hope thid helps
__________________
Current Rides
1972 f100 ranger xlt shortbed 302/auto 285,000
2004 ford freestar {the kidvan}
1986 bII 2.9 5spd 214,000 finally retired! currently rebuilding engine,hopefully running soon
1993 ford aerostar 307,000 going strong
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
