Distributor, dual diaphragm vs single diaphragm
From what I understand the dual diaphram model was used to be able to reduce hydrocarbon emissions. There are two diaphrams that work independently of one another. The front port goes to the "timed spark" port on your carburetor(like a conventional vacuum advance). The rear port goes directly to manifold vacuum to provide additional retardation of timing during closed throttle deceleration & idle to help with a reduction of hydrcarbons. Personally, if emissions weren't an issue, I'd replace it with a single diaphram unit & tune it to give you better power & mileage. Just remember anything that was designed to reduce emissions usually hurts performance. I hope this helps.
Todd
BB79RANCH
Todd
BB79RANCH
rangerottis
10-15-2014 08:17 AM
Sausage327
17
05-21-2014 06:26 PM
fordf348
04-02-2014 11:53 AM
meck1
01-11-2007 08:45 AM
300, 400, 460, diaphragm, diaphram, difference, diphram, distributor, distributors, dual, duraspark, ford, inline, single, vacumn
