2003 7.3L powerstroke wastegate surging prob. - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-08-2008, 07:18 PM
vdubin474 vdubin474 is offline
vdubin474 is starting off with a positive reputation.
When cruising down the road at a constant throttle position the motor will suddenly boost real hard for a split second and then go back to normal for no reason. The check engine light will then come on for about 30 seconds and go back off again. I had advanced auto scan it for me, but no code. I also can feel it boosting up ever so slightly and then off again when the motor is under a bit of a load with the throttle at a constant. So it's coming on and off while driving now as well, but not all the time.
I know it has to be something to do with the turbo wastegate actuator sticking maybe,vacuum leak, or an electrical sensor that actuates the actuator. I have never been elbow deep in a 7.3L powerstroke before so I don't know where to start. I want to fix this myself and any help on this would be greatly appreciated.
Old 02-08-2008, 07:29 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
Welcome to FTE. Go get that code checked from somewhere that knows what they are doing. Advance doesnt have the tools needed to scan a Powerstroke. Look for a buddy that has a program or tool like a snap-on scanner, or Autoenginuity. Or a buddy with something like a superchips or diablo tuner, that can pull codes for you. I'm betting it is something like the Injection Pressure Regulator valve sticking when you are easing into the pedal, when it sticks a little more closed than it should be, causing more fuel to be given, giving the surging feeling. The turbo has nothing to do with it, wastegate whatever, it only spools up and lets off for a little bit because it is being fed more fuel (energy to spool it). Im betting you have some code that is P12xx.
Old 02-09-2008, 05:17 PM
Thanks for the info brotha! That totally makes sense what you are talking about. I'm suppose to bring it to the dealer on tuesday to get the code read and I know they are going to try and take me to the cleaners. I know I could fix the prob myself if I knew what it was. I'm also screwed in the fact that I just moved up here so I have no friends in the Appleton, WI area that I could ask to scan my 7.3 for me.
Old 02-09-2008, 05:52 PM
griff64's Avatar
griff64 griff64 is offline
griff64 is starting off with a positive reputation.
Take the money you are going to spend at the stealership and go buy a Autoenginuity to get the codes. JMHO!!! Dave
Old 02-09-2008, 06:14 PM
How much does one cost?
Old 02-09-2008, 06:32 PM
MR5x5 MR5x5 is offline
MR5x5 is gaining momentum as a positive member of FTE.MR5x5 is gaining momentum as a positive member of FTE.
Unplug your wastegate and see if the problem remains. It's the red tube going to the side of the turbo. Stick it on a stud for safe keeping.
Old 02-09-2008, 06:58 PM
Now that i think about it, the other day I took off from a stop light and the dam thing took off like a bat out of hell. It had more power then it's ever had before like the wastegate was stuck closed. That tells me right there that it's got to be something with how the wastegate is controled. If I pull the vac line off of the wastegate actuator will it fail in the open or close position?
Old 02-09-2008, 08:27 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Quote:
$341.95 http://www.itpdiesel.com/store.php?c...on=show_detail
Old 02-09-2008, 08:48 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
This is a suggestion concerning the IPR (injection pressure regulator). Pull the connector off the ICP (Injection control pressure) sensor. The PCM will go to a default setting. Drive your truck and see if the surging is still there. Remove this connector with key off and replace with key off just to be on the safe side.
Old 02-10-2008, 01:09 PM
The default gat positon is closed. Also, FWIW, it is not vacuum operated it is pressure operated. Even with the red tube removed, the truck will defuel at 22-23 psi boost. When it defuels you will get an SES light for a few mintues and an overboost soft code.
Check your lines/connects to the map sensor, and the red line for cracks/leaks/defects. These are things in the "control circuit" for the wastegate.
Old 02-12-2008, 11:13 AM
Well, i took it to the stealership and there was a code with something about the ICP sensor is not reading. I told them i would put the new ICP senosr in and see what happens. They said the harness could be bad as well so i'm gambling with just replacing the sensor. Would the ICP sensor not picking up cause my symptoms? Sucks cause it costed 98$ to get a dam code checked and a new sensor is $166.00
Anyone know where on the net i can get a diagram of the 7 3 to see where this sensor even is? Thanks for all your help!
Old 02-12-2008, 11:38 AM
The sensor is located above the driver's side valve cover, on top, toward the front of the engine. Look directly across from the fuel bowl and you'll see it, I want to say it has 2 wires. It takes a 1" or so deep socket to remove. Very easy to access. Like Robin syas in post #9, one you locate it, unplug it and see if your problem goes away. The PCM has a default pressure table built in just in case the ICP fails. If it is a bad sensor, and you unplug it, the truck will drive absolutely fine. It will also throw a code when it detects the sensor "missing", not to worry, just expect/remember it.
If you need a new sensor check to e-bay. You should be able to find an new one for $50.
Old 02-12-2008, 12:46 PM
Yeah i just bought one for 70$ on e-bay. Thats was the cheapest one. Only problem is that i'm selling the van on e-bay and i have to fix this before i sell it. I don't know how long it will take for the sensor to arrive. So if i unplug the ICP tonight while i'm waiting for the new sensor and my probs go away then it was the sensot right? what is the PCM?
Old 02-12-2008, 12:51 PM
If you unplug it and it goes away, it certainly points strongly to the ICP being the problem. I had with a fluctuating idle that turned out to be the ICP. With the engine runnning, and flucuating, I could unplug the ICP and it would smooth out immediately.
PCM is the Power Contol Module (or something along those lines) it is the main computor.
Bilstein 5150 emmagator 1999 to 2016 Super Duty 10 03-07-2008 12:01 PM
302 in the machine shop 65fordguy Performance & General Engine Building 21 02-01-2008 11:22 PM
Performance programmer 2005 5.4L F150 fireman29b Computer Chips & Tuners 11 01-16-2008 07:18 PM
7.3L PSD dies under load nikel 1999 - 2003 7.3L Power Stroke Diesel 1 01-01-2008 02:02 PM
1984 460, not getting enough gas to carb, Fuel system problem? PLEASE HELP b33cpe 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 02-04-2007 01:45 AM
Tags
2003, 73, 73l, 99, actuator, diagram, diagrama, f250, filter, ford, fuel, gate, powerstroke, sticking, turbo, waste, wastegate, wastgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
