Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-08-2008, 03:07 PM
hawken50 is starting off with a positive reputation.
stock 86 B2 2'' suspension lift question
need opinions/advice: i have a stock 86 B2 eddie bauer 4x4 with 2.9 engine. i want to install a 2" coil spring spacer in front and a 2" steel block leaf spring in the rear. my local Big O dealer said that i would need to put on 4 new [longer]shocks on and that i may need to lenghten the steering. on the rear he said the 2" blocks could cause drive shaft vibration and that the blocks could slide on axle. my question is--- are any of these staements true and valid? i just put 4 new rancho shocks on less the 5K ago. he also said the 30/9.50/15 tires are too big for the 2.9. whats with that. thanks for any and all help. im just going for a new look and only use the B2 for hunting,no hard 4 wheeling. hawken 50
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-08-2008, 03:32 PM
5.0B2 is starting off with a positive reputation.
The mights and coulds are mights and coulds - If you get "clunks" from the shocks then they were too short - I ran the 30x9.50.15's on my 84 for 5 years with the 2.8, 3.73 gears, and c5 automatic without problems. My son broke two rear driveshaft ends on his with a stick shift and a lead foot.
__________________
1965 Falcon Ranchero hiPo 289 9"
1979 Lincoln Versailles 351W 4v
1984 BII 5.0FI 4R70W B/W 1356 d35 & 8.8/disks
1997 Explorer Sport 4.0 OHV
  #3 (permalink)
Old 02-08-2008, 09:17 PM
80351's Avatar
MD Chapter LDR
80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.
Quote:
I have a 90 2.9 2.5 lift 31X10.5/15 BFG's. Front is up with the spacers that go on the bottom spring seat. The rear was up with 2" blocks until I broke 1 of the leaf springs (not lift related) and replaced with Explorer springs.
When I replaced the springs I found that the blocks had cracked right in half.
Rear spacer blocks at least the aluminum ones are not good for off roading.
As for the shocks normally if you look at someone like Rough Country the shocks are listed 0-2". I have basically the stock length shocks and have not had any problems with bottoming or hitting.
The leaf springs I bought from Auto Zone and put 2 more leafs in them.
If you want more info on the leaf spring replacement you can go to
www.therangerstation.com . Go to forums, tech library, down the center column to lifts for cheap, all the way down the bottom is explorer leaf swap.
Cost me I think less than 200 bucks.
Hope this helps.
If you need more PM me.
__________________
Dave MD Chapter Leader
Mid Atlantic
89 Bronco 90 BII
03 Liberty
Join the Maryland Chapter click HERE
Jeepers Cheat, Ford people are true Blue
  #4 (permalink)
Old 02-09-2008, 07:34 PM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
That is 'wack" stuff, just get some Explorer springs.
Not recommended, just use Explorer 4 dr leaf springs.
Maybe, maybe not. Look up the shock in the Rancho catalog and see what it lists for the max. compression and extension limit. Many of the Ranchero shocks are designed for a 4" lift!
Your steering shaft goes from the body to a box mounted on the frame. I don't see where the suspension comes into play, then again I don't work at Pepboys or Big O
A drop pitman arm, since it is actually attached to the suspension, maybe, I doubt it. Lengthen the steering, I think not unless you did a body lift.
It can on the Bronco II just because it is a very short shaft. Most people do not have a problem. The biggest problem is the length of the slip joint.
If you have 3.73 or 4.10 gears it is no problem. They are a tad large for the 3.45 ratio, especially if you have an automatic and tow.
But for this
They are fine.
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
  #5 (permalink)
Old 02-09-2008, 08:58 PM
80351's Avatar
MD Chapter LDR
You DO NOT HAVE TO change the Pitman arm
DO NOT put blocks on the back they crack
You DO NOT have to change the steering shaft, drive shaft
You CAN USE the same shocks you have now
DON'T worry about the slip joint.
A 2 inch lift is the most you can do without having to do anything else.
Go to the MD chapter thread. Look for the thread marked members photo gallery.There will be a bunch of shots of fire trucks keep going, I have the blue full size, next is my red BII, with 31.50X10.5/15's and I do have 373 gears.
Believe me I did this 3 years ago and it still rides fine.
Actually this has been my daily driver for the last 5 years. The only reason I don't drive daily now is because the motor is going (2K+ miles) and has been.
If you still have all these doubts and questions the go over to The Ranger Station everybody there has Ranger based trucks.
If I would have had to change all that crap it wouldn't have been lifted $$$$$$$$ I didn't have many.
And again I DO WHEEL mine
__________________
Mid Atlantic
89 Bronco 90 BII
03 Liberty
  #6 (permalink)
Old 02-09-2008, 10:27 PM
DesertStorm's Avatar
DesertStorm is gaining momentum as a positive member of FTE.DesertStorm is gaining momentum as a positive member of FTE.
On my 85 I had the factory 4.10 gears and L/S. I put on a 2" body lift in about 4 hours, slapped on some 31x10.50r15 TSLs and wheeled the crap out of it for 3 years. No probs. My dad is still driving it today. Same setup minus TSL's. 2.8L auto. Got 160K on the clock. Darn good truck
__________________
Member of South Carolina Mudboggers Association
94 Ranger 2wd sittin on 33x12.50's.
93 Ranger 4wd sittin on 39's.
Proud owner of 2008 F-150 4X4!!!!!!!
Needs Boggers and Lincoln Lockers
I hate Toyotas.
  #7 (permalink)
Old 02-09-2008, 10:35 PM
80351's Avatar
MD Chapter LDR
Quote:
Body lifts are illegal in the state of Maryland and as I have a state inspectors license although for trailers and the cops are A**holes it could reflect on my licensing which is not needed.
__________________
Mid Atlantic
89 Bronco 90 BII
03 Liberty
  #8 (permalink)
Old 02-09-2008, 10:38 PM
80351's Avatar
MD Chapter LDR
Hope this works if so here is my 90 BII
__________________
Mid Atlantic
89 Bronco 90 BII
03 Liberty
  #9 (permalink)
Old 02-09-2008, 10:42 PM
Quote:
big10-4 on that
__________________
I hate Toyotas.
  #10 (permalink)
Old 02-09-2008, 10:43 PM
Sharp ride my friend.
__________________
I hate Toyotas.
  #11 (permalink)
Old 02-10-2008, 09:33 AM
tbolt 460's Avatar
tbolt 460 is starting off with a positive reputation.
good lookin B2, except for the ranger visor
__________________
88 BII(208,000mi still going) chop project
90 BII,2.9/C5/D44/9in
86 Ranger Xcab STX 4X4,D35,8.8,456's locked,4in lift
94 Xlporer sport
95 Ranger short bed 4X4 3.0 5spd
http://gearheads.ipbfree.com/index.php?s=&act=idx
  #12 (permalink)
Old 02-10-2008, 10:20 AM
80351's Avatar
MD Chapter LDR
You know what? I didn't think I would like that, but
driving the big one, I really miss it.
It looks empty when looking out the windshield.
I bought a small set of rear flares on ebay for it, but
when I got them they were cut outs and I really don't
want to cut the wells out that far besides the wells
aren't that bad.
__________________
Mid Atlantic
89 Bronco 90 BII
03 Liberty
  #13 (permalink)
Old 02-10-2008, 10:23 AM
tbolt 460's Avatar
theres 3 different visors for the rangers/B2's, you still have the cut outs
__________________
94 Xlporer sport
  #14 (permalink)
Old 02-10-2008, 10:37 AM
80351's Avatar
MD Chapter LDR
Yep, Interested?
They are from Duff and are the ABS ones.
I'll have to look and see what I have in them coast wise
but it was cheap and I'm tired of them being in my way.
__________________
Mid Atlantic
89 Bronco 90 BII
03 Liberty
  #15 (permalink)
Old 02-10-2008, 10:40 AM
tbolt 460's Avatar
maybe, how much
__________________
94 Xlporer sport
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
