Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 02-10-2008, 10:41 AM
tbolt 460's Avatar
tbolt 460 is starting off with a positive reputation.
are they the cut out,bolt on ones
__________________
88 BII(208,000mi still going) chop project
90 BII,2.9/C5/D44/9in
86 Ranger Xcab STX 4X4,D35,8.8,456's locked,4in lift
94 Xlporer sport
95 Ranger short bed 4X4 3.0 5spd
http://gearheads.ipbfree.com/index.php?s=&act=idx
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 02-10-2008, 10:54 AM
80351's Avatar
MD Chapter LDR
80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.
Quote:
Originally Posted by tbolt 460
maybe, how much
I'll have to look up my ebay receipt, I'll let you know
later today.
__________________
Dave MD Chapter Leader
Mid Atlantic
89 Bronco 90 BII
03 Liberty
Join the Maryland Chapter click HERE
Jeepers Cheat, Ford people are true Blue
  #18 (permalink)
Old 02-10-2008, 11:00 AM
tbolt 460's Avatar
Quote:
Originally Posted by 80351
You know what? I didn't think I would like that, but
driving the big one, I really miss it.
It looks empty when looking out the windshield.
I bought a small set of rear flares on ebay for it, but
when I got them they were cut outs and I really don't
want to cut the wells out that far besides the wells
aren't that bad.
never mind, there cut outs. my body is to good to cut
__________________
94 Xlporer sport
  #19 (permalink)
Old 02-10-2008, 02:20 PM
80351's Avatar
MD Chapter LDR
tbolt,
I would shoot you if you put these on that truck.
Matter of fact, I'd shoot you 2 or 3 times, that's
why I won't put them on. Granted there is some rust
on the lip and little piece down the bottom but know
where near enough for anything that drastic.
I think if mine looked like that about the only thing I
might do would be to hunt for a cowl induction hood
but that's all.
__________________
Mid Atlantic
89 Bronco 90 BII
03 Liberty
  #20 (permalink)
Old 02-10-2008, 02:33 PM
tbolt 460's Avatar
hunt for a cowl induction hood huh
HMMMMMM. no that would look cool,seeing im gonna put a 302 in it
__________________
94 Xlporer sport
  #21 (permalink)
Old 02-10-2008, 02:47 PM
tbolt 460's Avatar
i put the flexie flares on it. dont like um but it keeps the cop away
__________________
94 Xlporer sport
  #22 (permalink)
Old 02-10-2008, 04:29 PM
80351's Avatar
MD Chapter LDR
Hey,
Instead of hi-jacking this guys thread anymore,
why don't we go over to the MD Feb B/S?
__________________
Mid Atlantic
89 Bronco 90 BII
03 Liberty
  #23 (permalink)
Old 02-11-2008, 12:40 AM
HappyJack has a very good reputation on FTE.HappyJack has a very good reputation on FTE.HappyJack has a very good reputation on FTE.
Quote:
Originally Posted by hawken50
need opinions/advice: i have a stock 86 B2 eddie bauer 4x4 with 2.9 engine. i want to install a 2" coil spring spacer in front and a 2" steel block leaf spring in the rear. my local Big O dealer said that i would need to put on 4 new [longer]shocks on and that i may need to lenghten the steering.
Your shocks will most likely work for what you want to use it for. Shocks are used to limit wheel travel on many vehicles and your Rancho's should do fine if only a bit short. Real damage comes from the shocks being too long and bottoming out with the full weight of the vehicle under compression. Might have to jack the axle up a bit to hook up the shocks is all. If you wanted max flex you'd need to measure full extension with the shocks un hooked.
I like coil spacers and I made my own with large washers (I was only able to get a bit over an inch) for my 89. But I put a 2" rear long add a leaf and new front leveling coils and did use longer shocks when I did. And a new proper lenth double cardan rear drive shaft. The steering should have enough adjustment in it. You might need after market larger off set adjuster cams to obtain proper alignment.
Explorer front coils (I beleive there were at least two different ones) are made of thicker wire and wound tighter than your BII coils. They also have a shorter free standing height. They just don't compress or extend as much. So they will give you front lift and work with your shocks. How much lift depends on which Explorer coils you get and which Bronco II coils (there were a number of these also) you have now and the condition of each. The Explorer springs will give you a firmer ride but will not work as well (flex) off-road.
on the rear he said the 2" blocks could cause drive shaft vibration and that the blocks could slide on axle.
Rear blocks do promote axle wrap and cause leafs to break(mostly on older weeker leaf packs). But they also do well when installed with new or very good rear leafs and new, quallity u-bolts. They should be torqued properly and check again after 200-500 miles. And they put three different types of rear driveshafts in the rear of the Bronco II. The CV style is the least forgiving. Next would be the single u-joint shaft. And the most forgiving would be the double cardan rear shaft. So any rear lift could cause vibration depending on type and condition of your rear drive shaft. If you have the Cv style rear drive shaft I would plan on a upgrade to at least a single u-joint new shaft.
Again Bronco II and Explorer rear springs differ and there were a number of different spring packs used. The BII packs had thinner leafs and as a rule more leafs. The thinner/more leaf design has been used for years for longer travel suspensions.
I might offer another choice for the rear. Add a leafs are available in a short and long version. The short version is very close in cost to a block kit. Rides stiffer. And is easier to install than the rear Explorer springs. The long add a leaf is more expensive but rides much nicer.
my question is--- are any of these staements true and valid? i just put 4 new rancho shocks on less the 5K ago. he also said the 30/9.50/15 tires are too big for the 2.9. whats with that.
Should be a door sticker on your Bronoc II that has stock tire size and axle ratio code. There are places that you can plug those numbers into then put in the tire size you want to go to (in this case the 30" tall tire). You will then be given a range of axles ratio's (gears) to change to. My 89 did great with 30 X 9.50's and 4.11 gears. With stock gears, the lift and 30" tires, it had really bad fuel mpg.
thanks for any and all help. im just going for a new look and only use the B2 for hunting,no hard 4 wheeling. hawken 50
I hope this helps out. As you can see there are different points of view on this. Folks use these little trucks for different things. Dailly drivers to trailer queens. And it seems some states have rules that others don't. Bumper height or head light laws. So check what you have in CA first. I'm lucky and we don't even have smog checks in KS. And I do like body lifts if done properly. But as with rear block kits I would not use them on a old, worn, 20 year old truck suspension.
Let us know how this works out for you.
__________________
Happy "Lonesome Beaver" Jack
"Jr." All Grown Up
SSRNC Member #0
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
