compression
compression
hi Cecil, well i take a stab at it. i'm assuming you just rebuilt this engine. because you said you have flat top pistons. the '73 460 engines i've seen have dished pistons about 19 to 22 cc. dished for the lower compression. using flat top and having the heads shaved that much, i would bet that your in the neighborhood of 9.5:1 to about just under 10.0:1. you didn'y say if you had bored the block. don't for get to compensate for the shaving, your are most deffinitly going to have to use shims under the rockers to bring your lifter pre load back into specs. have a great weekend. C.J. later.....
dburgess
18
12-14-2020 12:24 AM
BigBlocker0248
01-17-2016 03:20 PM
greentruck72
05-04-2015 04:02 PM
walt80
12-17-2003 10:38 AM
