4.6 belt routing pic/diagram - Ford Truck Enthusiasts Forums
Old 02-07-2008, 10:50 AM
goatboyposer goatboyposer is offline
goatboyposer is starting off with a positive reputation.
Exclamation 4.6 belt routing pic/diagram
hi all,i could really use a routing diagram/pic ,for a 1999 f150 4.6 with a/c.any help would be appriciated greatly,thanx all,the goatrancher
Old 02-07-2008, 02:54 PM
Joe Finn's Avatar
Joe Finn Joe Finn is offline
Joe Finn is gaining momentum as a positive member of FTE.
There should be a sticker on the radiator cover with a diagram. Unless it fell off, which would explain your post...
Old 02-07-2008, 07:50 PM
thanxs,no my dumba,, self never put it back on after a body lift,several years ago.ive since fixed the belt today.so thanks anyhow.on a lighter note,all you need is a tin can,if you want a date with a goat.lol
Old 02-07-2008, 08:38 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
Weird stuff going on here. Would a Bud Ice can work?
Plug Wire Routing for a 4.9L I6 manual? Necromancer 1987 - 1996 F150 & Larger F-Series Trucks 6 05-08-2014 12:22 PM
serpentine belt routing black cloud 6.0L Power Stroke Diesel 2 10-19-2010 09:45 AM
97 F150 4.6L Belt Diagram dlynx 1997 - 2003 F150 2 04-16-2004 02:38 PM
1997 Ford f150 4.6 fuse panels diagrams prange55 1997 - 2003 F150 1 03-07-2004 09:44 AM
Need Vacuum Diagram 2002 4.6 n0esc Explorer, Sport Trac, Mountaineer & Aviator 0 11-04-2003 06:06 PM
Tags
1999, 2002, 46, 46l, 97, 99, belt, diagram, engine, f150, ford, liter, route, routing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
