Quote:
Originally Posted by mcdhighboy
any ideas if i can swap a 1994 (I think) 7.3L diesel into a 1977 highboy with a 351M? will 4 speed manual bolt up and any other problems I may run into?
thanks
From what I've been told the bellhousing is different, you can bolt a 460 up to it though. Being a Highboy you could put a 4 speed from a diesel in the truck and make a new middle drive shaft to connect to the T-case. I'd be afraid of the case twisting too much with the added torque. Couldn't belive how much they move when horsed.
You'll need to beef up the front suspension, along with the cooling system.
All depends on how much money you want to spend.
__________________
79 250 Ranger Lariat 429 4v, Duals, Built C-6, 4wd, B&W
97 250 Powerstroke Ex Cab, 4wd, 5 spd, 3.55, 6637, AIC, gauges, DP, 4" straight, B&W, air bags, ex brake, FPR, HPX, TW
96 350 Powerstroke 4x4 Dump, Luk SMF, 6637, 4", ex brake
