breakerless ignition - Ford Truck Enthusiasts Forums
Old 02-07-2008, 12:45 AM
larry51 larry51 is offline
larry51 is starting off with a positive reputation.
I have a 72 f100 with a 390 and i want to put a breakerless ignition in it. What is the best fit and where do I find it. Thanks
Old 02-07-2008, 12:49 AM
scrapyardking scrapyardking is offline
scrapyardking is gaining momentum as a positive member of FTE.
Just go to the junkyard and get all the stuff off of a 70's truck
Old 02-07-2008, 10:01 AM
sleep_deprived129's Avatar
sleep_deprived129 sleep_deprived129 is offline
sleep_deprived129 is starting off with a positive reputation.
I used Accel's 'Points Eliminator' on my truck and it worked great. You can find em on Summit for not too much.
Old 02-07-2008, 11:41 AM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
i have a performance distributors dui on mine. with wires it cost me freakin 500 dollars!
the difference is definitely there, but its not "holy smokes/ night and day difference"
its a nifty thing to have and i do like it, but if i could turn back time da da da da, i would not have bought it.
Old 02-07-2008, 02:40 PM
zrtkicks zrtkicks is offline
zrtkicks is starting off with a positive reputation.
Pertronics, jegs or summit, $69.00, easy as pie install, and I use mine in a pulling truck, it has never missed a beat. I love it.
Old 02-07-2008, 04:38 PM
wizzard351's Avatar
wizzard351 wizzard351 is offline
wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.
ford dura sprk from a 1976 360 and a wiring harness with a brain box is less then 50 bucks at the salvage yard. even if ya have to buy a new dist there only 50 buck too
Old 02-07-2008, 07:23 PM
1966Mercury 1966Mercury is offline
1966Mercury is starting off with a positive reputation.
I put a Pertronics in my 72 F250 360 when they came out years ago. It is still in there and all I do is change the cap and rotor about every 2 years. I now use them in all my pre-eletronic ignition Fords. I also get the coil they reccomend and paint the top yellow so it looks close to the original coil. I think getting the matching coil makes it work even better. Just my .02 worth.
Old 02-07-2008, 07:27 PM
rhetor rhetor is offline
rhetor is starting off with a positive reputation.
I would make sure to get a system that allows you to use a modern high power 12v coil without a resistor wire or ballast. This way you get big spark all the time!
My boss put a mallory points-less distributor in his 351c, and the instructions said to keep the resistor wire or the warranty would be void! What?!? Isn't the whole point to be able to use a high power coil without frying the points? I understand its lower maintenance, but seems a bit dumb to me.
Old 02-07-2008, 10:08 PM
convincor convincor is offline
convincor is starting off with a positive reputation.
I've been using Pertronix and never had a problem but I think I'll try the Crane XR-i next...
Old 02-08-2008, 01:54 AM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
A great conversion is to use the Duraspark from a 1975-up Ford vehicle along with a late-model TFI coil. I did the conversion on my '68 as well as Fastmover's '70.
It's possible to convert a points distributor to Duraspark but since it was available on FE engines anyway, it's easiest just to get the Duraspark FE distributor. If you want to go this way, I can supply you with a wiring diagram and more info.
Old 02-08-2008, 05:57 PM
qman qman is offline
qman is starting off with a positive reputation.
I did the Pertronix and it is easy as pie. I'd have done a duraspart from a newer truck but for a few bucks more you don't have to dig in the salvage yard. It is much better than dealing with points every now and then.
Old 02-18-2008, 02:41 PM
AirborneRanger AirborneRanger is offline
AirborneRanger is starting off with a positive reputation.
I used a Crane Cams XR-1 in my '69 F700 361ci Firetruck...I'm no mechanic but install was easier than fixing a software problem on my computer. Runs sweet! $65 at Summit.
Old 02-18-2008, 05:35 PM
71swissaqua's Avatar
71swissaqua 71swissaqua is offline
71swissaqua is starting off with a positive reputation.
I like the Duraspark dist. with an aftermarket 12volt coil and a GM HEI module
Cheap easy and a HOT spark.
Old 02-18-2008, 09:27 PM
CN Spots's Avatar
CN Spots CN Spots is offline
CN Spots is starting off with a positive reputation.
I have the Crane XR-1 in my 390 as well. Runs like a top!
Old 02-18-2008, 09:47 PM
baitmaster baitmaster is offline
baitmaster is starting off with a positive reputation.
easy as pie!
After changing points many times, I installed a Pertronix sys in my '72 390. That was over 10 yrs ago, and the only thing I have done since is 1 cap and rotor. Best $69 I ever spent.
Breakerless Ignition Module Qs Sparkplugless 1957 - 1960 F100 & Larger F-Series Trucks 1 05-20-2016 08:56 PM
Electronic ignition in 70's FT bigcrunch Large Truck 15 01-26-2016 02:10 PM
my 1953 ford will not crank but it turns over. help 53rmod Electrical Systems/Wiring 2 12-11-2015 11:38 AM
Pertronix ignition in y block hoss73ford 1961 - 1966 F-100 & Larger F-Series Trucks 9 06-28-2015 10:47 PM
Dura Spark II Upgrade For FE Series Engine ScallyWaggler 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-16-2015 03:17 AM
Tags
1978, 361, 390, 72, accel, breakerless, distributors, f100, f700, ford, ford390breakerless, ignition, pertronix, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
