1992 7.3l idi none turbo, no power - Ford Truck Enthusiasts Forums
Old 02-06-2008, 11:02 PM
Krupka Krupka is offline
Krupka is starting off with a positive reputation.
1992 7.3l idi none turbo crew cab long box 4.10 gears 5 speed manual.
I have been pulling a 20 foot car trailor with three atv's on it for a while now, but the last two runs i made with it i noticed a major loss in power. With just a slight incline i am not able to hold 60 mph. Even if i down shift to 4th gear i still loose speed. I also noticed that a run that normaly used less than a half a tank of fuel now uses almost a full tank. I changed the fuel filter and it did not make any differance. I checked the fuel pressure and came up with 4 psi. I was told that 4 psi is in spec but on the low side.(still has a manual fuel pump) The only other place i can think to look is the injection pump, but i have no idea how to test it. I was told this engine was rebuilt before i bought the truck about 60,000 miles ago. The loss of power happened over one weeks time.
This truck should be able to pull more than that, correct?
How can i test the injection pump?
Any other ideas would be helpfull.
Old 02-06-2008, 11:32 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Check the air filter and fuel filter......... do you use any fuel additive. When you remove the fuel cap do you get a sucking sound. Any smoke seen and what color...
Old 02-07-2008, 08:27 AM
The air filter is fine, and i already replaced the fuel filter. I use anti gel. It's not poor fuel quality, i have ran 4 tanks through with the same problem. black smoke on hard accell. (it has always smoked under load)
Old 02-07-2008, 10:12 PM
speedrdr speedrdr is offline
speedrdr is starting off with a positive reputation.
have you checked the CDR valve behind the breather assembly lately? mine was nasty gunky and cleaned it. made difference.
speedrdr
Old 02-07-2008, 10:20 PM
KJLYPW's Avatar
KJLYPW KJLYPW is offline
KJLYPW is starting off with a positive reputation.
Check that your e brake cables are all moving free- possibility that brake drag is causing performance issues?? Does your truck smoke at idle even when warm? Check for pressure build up in your tank, or a restricted return line system, these will affect your dynamic timing, causing balck smoke and poor milage. Restriction in the exhaust?
Old 02-07-2008, 10:23 PM
Darrell Maryland's Avatar
Darrell Maryland Darrell Maryland is offline
Darrell Maryland is starting off with a positive reputation.
Do you have a picture of the CDR valve , I wan to clean mine . and what is a CDR
Old 02-07-2008, 10:33 PM
KJLYPW's Avatar
It's the tuna can shaped part bolted to the back of the intake, and clamped to a rubber coupling that connects to the valley cover/crankcase. Be carefull with the clamp and rubber coupling, they get brittle where the grommet attaches to the valley pan. (Crankcase Depression Regulator)-same as the PCV on a gasser. Good placed to start- should be cleaned every other oil change. soak in gas and slosh out until clean, do not use compressed air, check for broken diaphram, clear small vent hole on back of can, reinstall when completely dried out.
Old 02-08-2008, 06:55 PM
I will check the CDR valve. E brake cables are not hooked up, and the exhaust is not pluged.
Old 02-09-2008, 01:36 PM
I checked for this cdr valve, and it was not there. Someone must have removed it from this engine. Where could i get one of these? I checked with the parts stores and none of them have a part number for them.
Old 02-09-2008, 03:51 PM
i think this is a ford dealer item, but someone else may know better.
speedrdr
Old 02-10-2008, 12:14 AM
I am not convinced that this is my problem though, since the problems just started.
Old 02-10-2008, 05:59 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.fonefiddy is gaining momentum as a positive member of FTE.
No, it's not your problem.The CDR is not going to effect performance to any significant degree.
I'd suggest checking the feul system. Look for any leaks.
Does it start OK?
Old 02-10-2008, 01:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
This is the CDR.
Either Ford or International (Navistar) would be the place to get a CDR.
Old 02-10-2008, 02:05 PM
Is 3 psi of fuel pressure ok?
I have checked it over for fuel leaks a few times now and can not find any.
I still have the stock fuel pump on it, and i will change it to electric if it seems to be the cause of my problems.
I am just not shure about the injection pump?
Old 02-11-2008, 08:32 PM
What could i use for an electric fuel pump on this engine?
Some great sensor information fordpride 1999 - 2003 7.3L Power Stroke Diesel 15 05-23-2016 02:00 PM
Burning to much fuel Houston Perez Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 11-20-2015 02:59 AM
Last Resort: Injection Pump? guisepi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 12-15-2013 01:27 AM
How HEUI works and best to convert FN74 Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 09-29-2009 11:35 PM
loss of power after trip to dealership misterc 6.0L Power Stroke Diesel 4 07-27-2008 09:11 PM
Tags
1992, 73, 73l, 92, cdr, diesel, f350, ford, idi, lacks, power, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
