1992 7.3l idi none turbo, no power
Old 02-12-2008, 12:33 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
Holley Red pumps have been used with good results by several of the users in here.
3 PSI is a bit low in my opinion, mine sets at about 6 PSI at idle.
Old 02-12-2008, 10:00 AM
AndysFords's Avatar
AndysFords
AndysFords is offline
You really can't test for a weak injection pump on the truck, you would have to pull it off and have it tested at a local injection service shop. Of course, if it were me, by the time I got it off I would go ahead and have it built.
Old 02-12-2008, 11:15 AM
lazyscholar's Avatar
lazyscholar
lazyscholar is offline
try looking at the return lines i had a similar problem, and one of my original rubber lines were cracking and lesking diesel, wouldnt explain the power loss though, also may want to check the plastic caps, and the injector o rings.
Jeff Kelly
05-15-2017 03:45 AM
Resendiz
26
08-23-2016 04:24 PM
fordpride
15
05-23-2016 01:00 PM
Houston Perez
11-20-2015 01:59 AM
fordpride
06-26-2012 10:49 PM
Quick Reply: 1992 7.3l idi none turbo, no power
