Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-06-2008, 08:00 PM
guthrie&co's Avatar
guthrie&co guthrie&co is offline
Garage is empty, add now
guthrie&co has a very good reputation on FTE.guthrie&co has a very good reputation on FTE.guthrie&co has a very good reputation on FTE.
what do you do with the waste from bio production?
I am thinking of getting the fuel mister system and the only hold back is what do you do with the waste from production?
__________________
Daniel
We can only know the fullest joys of Masonry when we truly walk the paths of service and of hard work in the quarries. -George E. Burow
  #2 (permalink)
Old 02-06-2008, 09:23 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
You have several options: 1, If you use NaOH the glycerol makes a great weed killer. 2, If you use KOH you can use the glycerol as a fertilizer. 3, In the right burner it can be used as process heat. 4, You can make soap out of it. 5, When mixed 50-50 with water it can be used as a dust control for gravel roads. 6, If you use KOH you can add up to 10% by weight as a feed supplement in livestock feeds.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 02-07-2008, 08:05 AM
guthrie&co's Avatar
The first and last options sound the best to me. As a landscape contractor that would help me there but I don't know what my mix rates would be nor would I be able to produce the required documents when the pesticide inspector comes around. Might have to do some research on that. The last option is what I feally like. How would I go about selling the stuff to the feed mills Since I dont have any livestock
Oh and fill me in please what is NaOH? and KOH?
__________________
Daniel
  #4 (permalink)
Old 02-07-2008, 09:37 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
NaOH = Sodium Hydroxide (draino)
KOH = Potasium Hydroxide
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #5 (permalink)
Old 02-07-2008, 07:25 PM
guthrie&co's Avatar
i take it that those are ingredients that you use with the methanol and wvo to make the bio?
__________________
Daniel
  #6 (permalink)
Old 02-07-2008, 08:20 PM
1935 Ford pickup
Yes. Try this site first: http://www.biodieselcommunity.org It has tutorials that will take you thru the process from start to finish. Plans to build an "appleseed" style processor, and suppliers that will sell you a kit. If you have questions, come back here and one of us will try and find an answer for you.
Good luck! I'll start my 5th year on biodiesel next month.........
__________________
  #7 (permalink)
Old 02-08-2008, 12:16 PM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Gun-Driver is starting off with a positive reputation.
Hey Fabman,
A couple of questions for ya,
1) Is the NaOH still a weed killer with the methanol removed.
2) I'm sure you have to remove the methanol from the KOH before using it for fertilizer don't you?
3) Do you apply it straight or do you thin it with something for fertilizing?
And last question
How can you tell if you have all the methanol out of it?
  #8 (permalink)
Old 02-08-2008, 02:33 PM
1935 Ford pickup
Quote:
Originally Posted by Gun-Driver
Hey Fabman,
And last question
1) NaOH based glycerol without the Methanol is a very good weed killer, [it's the Sodium that kills]
2) You would not HAVE to recover the Methanol from the glycerol, [ it will soon evaporate in a short time] It just makes economic sense to recover as much as you can.......
3) I use it on my alfalfa fields, mix it 50/50 with water, and apply at 8 gal per acre.
Last question, Once you start recovering the Methanol [ which ever method you use] it will slowly stop producing methanol, when it quits "dripping" it's done
__________________
  #9 (permalink)
Old 02-08-2008, 03:07 PM
Gun-Driver's Avatar
Last question, Once you start recovering the Methanol [ which ever method you use] it will slowly stop producing methanol, when it quits "dripping" it's done[/quote]
Thats what I do but I'm always a little gun shy to spray it on my lawn, in case for some reason there's some methanol left in it.
  #10 (permalink)
Old 02-08-2008, 08:03 PM
1935 Ford pickup
Try it on a small patch where you have a hard time growing grass and see how it works.............
__________________
  #11 (permalink)
Old 02-12-2008, 10:57 AM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
I spread mine out on the ground on a sunny day and let whatever methanol is left evaporate out. When I switch to KOH I will probably mix some in with the cattle feed.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
Tags
biodiesel, bioproduction, control, desert, fertilizer, fertillzer, glycerin, glycerine, glycerol, killer, lawn, make, methanol, naoh, spread, weed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
