429 2V-4V..? - Ford Truck Enthusiasts Forums
429 2V-4V..?
Old 02-11-2001, 08:53 PM
nosvmax nosvmax is offline
nosvmax is starting off with a positive reputation.
429 2V-4V..?
I have a 71 429 2v and was wondering if there is a difference between the 2v heads and the 4v heads. When rebuilding, I'm planning to go to a 4 barrel.
Thanks,
John C
Old 02-11-2001, 09:12 PM
bb79ranch bb79ranch is offline
bb79ranch is starting off with a positive reputation.
429 2V-4V..?
[font size="1" color="#FF0000"]LAST EDITED ON 11-Feb-01 AT 09:14 PM (EST)[/font][p] There is or was no difference between the base model 429-460 heads, whether for use with a 2 barrel or 4 barrel. They only changed the manifold's configuration. BTW the 429 used both 2 barrel and 4 barrel manifolds where as the 460 ONLY used a 4 barrel manifold during production.
Todd
BB79RANCH
Old 02-11-2001, 09:20 PM
429 2V-4V..?
Thanks todd
Old 02-17-2001, 03:24 PM
cobrajet cobrajet is offline
cobrajet is starting off with a positive reputation.
429 2V-4V..?
hey John C., what's up? yes Todd is correct on the head info. the only other difference in these are the compression ratios. the 2v engine is 10.5:1 at 320 hp. at 4400 and 460 lb.ft of torque at 2200 r.p.m. and the 4V engine is 11.0:1 ratio at 360 hp at 4600 and 480 lb. ft. of torque at 2800 r.p.m. these numbers are taken from the ford service manual. take it easy. C.J. later.........
Old 02-17-2001, 06:02 PM
429 2V-4V..?
Thanks CJ for the info
Hey, should I get any head work done when I start to re-build other than general? I plan to go to a aluminum intake w/ 4 bbl,
cam, bore if I have to, pistons, crank turned if needed. The engine only had 100k on it when removed.
And..any ball park figure on HP..? also any tips you may have
thanks again
John c
Old 03-27-2001, 02:26 PM
ilikefordbroncos ilikefordbroncos is offline
ilikefordbroncos is starting off with a positive reputation.
429 2V-4V..?
Old 03-30-2001, 03:02 PM
stingrayj72 stingrayj72 is offline
stingrayj72 is starting off with a positive reputation.
429 2V-4V..?
I'm sure these guys are correct, I just wanted to add that on a Pontiac (I know) 400 there was a 2v and 4v head and the 4v heads specifically flowed better for the 4 barrel and stock 2v heads with a 4 barrel would still basically perform as a 2v with a 2 barrel.
429 or 460? shadow_almanza 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-01-2010 08:55 PM
2v vs. 4v heads on 385s torino_and_effie Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 01-03-2008 08:37 PM
429 identification katman469 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 05-18-2006 03:42 PM
429 or 460? jkt Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 04-22-2005 02:13 AM
71 2v heads vs 4v heads (429) nosvmax Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 12 12-08-2001 06:10 AM
Tags
2v, 429, 460, 4v, difference, ford, heads
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
