460 vac. hose route question - Ford Truck Enthusiasts Forums
Old 01-04-2001, 03:31 PM
a63unibody a63unibody is offline
a63unibody is starting off with a positive reputation.
I have a 78 460, on the air cleaner lid there is a valve, both vac lines are missing. Anyone know where these might go? Also the cartridge that looks like an oil filter, whats it for? Thanks
Robert
Old 01-04-2001, 03:43 PM
dre dre is offline
dre is starting off with a positive reputation.
If I am not mistaken, (been awhile since I've used that setup)
one hose goes from the lid to the valve on the end of the snorkel
(flap that lets in air on the end of air cleaner housing) and the other hose goes to a vacuum source, Carburetor).
Old 01-04-2001, 07:05 PM
Thanks, I'll check that out in the morning.
Robert
Old 03-26-2001, 09:21 PM
astamp78's Avatar
astamp78 astamp78 is offline
astamp78 is starting off with a positive reputation.
Old 03-27-2001, 01:26 PM
ilikefordbroncos ilikefordbroncos is offline
ilikefordbroncos is starting off with a positive reputation.
>the morning.
>Robert
There are hoses under the air breather on the breather box they run up from under there to the snorkel on the breather box.
Old 03-30-2001, 07:14 PM
TBirdGuy TBirdGuy is offline
TBirdGuy is starting off with a positive reputation.
I believe that "cartridge that looks like and oil filter" would be your breather element. If it's oil soaked, replace it. It is where post combustion gases escape from the motor throught the PCV valve back to the air intake to be 'reburned' for lower emissions.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Too much Vacuum advance? march 1973 - 1979 F-100 & Larger F-Series Trucks 15 06-22-2013 09:48 AM
OD Light on dash flashing 1966racer2 Clutch, Transmission, Differential, Axle & Transfer Case 4 05-14-2011 09:34 AM
Marine 460 robert collison Engine Swaps 4 11-29-2005 09:30 PM
Turbo Timers..... Robert6401 1999 - 2003 7.3L Power Stroke Diesel 15 09-30-2005 09:57 PM
Late 460's differences and specifications? E4ODnut Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 11-20-2002 12:47 PM
Tags
460, breather, flap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
