convertin 351M to 460 - Ford Truck Enthusiasts Forums
Old 02-20-2001, 07:52 PM
Heetseeker_1 Heetseeker_1 is offline
Heetseeker_1 is starting off with a positive reputation.
Old 03-21-2001, 10:58 AM
bambamn bambamn is offline
bambamn is starting off with a positive reputation.
I have an 81 1 ton 4x4 that has that damn gutless 351M. I want to swap in a 460. Has anyone done this conversion. Will all the brackets and accesories off the M bolt to the 460? Should I go with ext. balance or internal? What parts will I need to get the motor in? Different flywheel? Torque converter? Motor mounts?
Old 03-26-2001, 10:21 PM
astamp78's Avatar
astamp78 astamp78 is offline
astamp78 is starting off with a positive reputation.
go to landlpruducts.com, they make a kit for this conversion
I am going to do the same with my 78 ford bronco 4x4
I hate the 351m/400!
HATE IT! HATE IT! Biggest peice of trash in the world.
So I am putting a 460 in it. Ill get a bit better mileage and gobs of power without even building it up much.
Old 03-30-2001, 08:18 PM
TBirdGuy TBirdGuy is offline
TBirdGuy is starting off with a positive reputation.
As far as brackets are concerned, probabaly not. I did a swap (351-M out, 460 in) in a 79' T-Bird and NONE of my brackets would work. I don't know about the motor mounts. I'm sure you'll need a different flywheel and torque converter because although the 351-m/400 have the same bolt pattern as the 460, the flange on the crank is different, therefore requiring different flywheel and torque converter. Hope this helps.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
