Heads - Ford Truck Enthusiasts Forums
Heads
Old 04-01-2001, 11:24 PM
78bigblock 78bigblock is offline
78bigblock is starting off with a positive reputation.
Heads
My 78 460 is burning oil, smoking blue and has low oil pressure when hot. Could this be caused by bad valves in the head? I really dont wanna do a rebuild but if the heads are good then thats what it'll come down to!
Old 04-02-2001, 01:06 PM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
Heads
Sounds more like just plain ol' tired engine syndrome. The main bearings are worn which is causing your low oil pressure, the valve seals are probably shot which along with blowby past the rings is causing the oil consumption and blue smoke. If you had burned valves than you'd have low compression in 1 or more cylinders but not necessarily low oil pressure or blue smoke.
Old 04-02-2001, 04:38 PM
Heads
Thanx 4 the help. sound slike i will have to pull it and do the rebuild i guess.
Old 04-04-2001, 12:43 PM
460hipo 460hipo is offline
460hipo is starting off with a positive reputation.
Heads
Head swap? husker 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 08-01-2006 12:50 AM
porting 351w heads 78 Ranger Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 01-28-2006 12:54 PM
68 302 heads on a 78 351W FordPickup460 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 07-12-2004 03:14 PM
360 pistons 78broncoman FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 02-12-2004 09:55 AM
Doing oil mods? fordboy1973 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 05-28-2003 03:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
