460 identification - Ford Truck Enthusiasts Forums
460 identification
Old 04-05-2001, 01:34 PM
ir8mudeater ir8mudeater is offline
ir8mudeater is starting off with a positive reputation.
460 identification
I am interested in buying a 81 F250 w/ a 460 from a 74 Marquis, 9" total lift and 38.5" Swampers. What is the proper way to make an ID of the motor/auto trans? I trust the guy, I just want to make sure. I am a Mopar fan who is thinking of trying out Ford for the first time. Thanks in advance for the info. Also, any info about this motor would help!
Old 04-05-2001, 08:56 PM
rwjr rwjr is offline
rwjr is starting off with a positive reputation.
460 identification
the 460 is id'd easiest by the valve covers. they are basically prizm-shaped. the top of the valve covers are level along the full length except the very ends, where they turn down to the flange. both ends also look triangular. it's almst difficult to explain, but if there is a hump at one end or they do not resemble prizm's, then it is not a 460. also, the 460 valve covers have 7 bolts securing them; 3 along the top and 4 along the bottom.
the 460 is a very strong engine. i feel it is among ford's best enginesas far as transmission, if it's an auto, it almost has to be a c-6, as identified by a one-piece casing (bell housing is integral to the case)if it is a manual...there is so much to look at to determine exactly....a granny low is most likely an NP-435, and a regular 4 speed is most likely the T-18
Old 04-06-2001, 10:29 PM
etobolski etobolski is offline
etobolski is starting off with a positive reputation.
460 identification
7.3 idi in a 79 f250 snowracer 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-14-2012 01:02 AM
WTB - '73-'79 460 motor perches elgemcdlf WTB - Parts & other 1 09-08-2011 11:18 AM
1975 4x4 390 to 460 swap 79 Pulling Ford 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-11-2007 04:51 PM
460 swap danwalker20 Engine Swaps 7 10-30-2004 07:10 PM
460 Headers for 77 F-250 4X4 sandfantom 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-28-2000 10:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
