code readers needed!
Old 03-21-2001, 07:49 PM
jkt's Avatar
jkt
jkt is offline
I have a 429ci that I pulled out of a 1968 or 1969? LTD last summer and before I rebuild it I wanted to know what I'll have to work with. So if somebody can decipher this codes for me I would be very grateful.
Intake Manifold #:
C9AE-9425-A
Head #:
C8VE-E
Also will there be any more #'s that I will need in order to find out the specifics on this engine?
thank you
Josh
Old 03-27-2001, 01:35 PM
ilikefordbroncos's Avatar
ilikefordbroncos
ilikefordbroncos is offline
Old 03-30-2001, 01:12 PM
stingrayj72's Avatar
stingrayj72
stingrayj72 is offline
I too would like to find what vehichle my 429 origonated from an just what type of motor it is(power, specs ect.). Im guessing that a nearby major Ford dealer would be able to help.
Old 04-05-2001, 10:25 PM
bb78bronco's Avatar
bb78bronco
bb78bronco is offline
how's it going? the heads i know have 2.08 intake and 1.64 exhaust valves. not sure exactly but i think the cumbustion chamber size is 75 cc or close to it. any info you want about a big block ford go to http://www.385-series.com on the bottom of the page there are a couple of things to click on and one is info i believe click here and it will tell you what every number is for instance your heads it will tell you cc size, valve size, port size, and it will tell you different compression ratios for your engine and other engines with your heads it is a very good site. Hope this helps. Josh,,,,,,
Old 04-06-2001, 07:17 AM
cobrajet's Avatar
cobrajet
cobrajet is offline
listen all you ford fans. don't go visiting this 385 web site and think your getting correct info. this person i am definitly convinced doesn't know much about big block fords. he doesn't even know that the code for the cobra jet drag pack option is one letter ( R ) that's the only code and not CY or CV as he has listed.. that's just one for instance. there are many other mistakes,,, not enough time at this point to list any more... so PLEASE don't come out of this forum with a fat head thinking things are right lots of information is incorrect!!!........ later C.J.
Old 04-07-2001, 02:21 AM
xaviar's Avatar
xaviar
xaviar is offline
Hey CJ, How ya doing.
Could you suggest a good web site for BB Ford's?
Also, Jkt the # I come up with is, C9AE, (A, full size ford)like you said LTD/Galaxie (E engineering, powertrain dept.
Head C8VE, 68 head off a Lincoln
I imagine CJ could verify this info.
Xaviar
96 F-250HD 4x4 460/E4OD 4.10
Banks Power Pack, Banks Trans Command
MSD 8227 Coil, MSD 32199 8.5 Wires, MSD 6A
Old 04-07-2001, 02:49 PM
bb79ranch's Avatar
bb79ranch
bb79ranch is offline
AMEN CJ!!! What you have stated, I totally agree with.
It is nice to have a Website that can give good basic info on a Big Block Ford, the problem lies with the research and not here-say to prove what is technically right. Alot of people use this and other literature to help in their quest for information only to be proved wrong with either hurt feelings or worse, an empty wallet. I personally don't know CJ, but since I've been answering questions on this site, I've found that he answers most any 385 series question with utmost certainty on correctness.
Todd
BB79RANCH
Old 04-07-2001, 11:33 PM
cobrajet's Avatar
cobrajet
cobrajet is offline
thanks Todd! i try and do my best, even sometimes i'm not right. but i try to stay on top of the old stuff, and i answer them to the best of my knowledge. and i miss some things or just type in one thing while thinking of another, i bet that's happen to you too. have been messing with big blocks for many years now and have literally have 2 tons of engine parts 429/460. 5 complete engines, 20 pair heads, a few spare blocks, and about 25 pairs of small block heads all older than 1973. keep up the good work yourself you know quite a bit also. got to go. later. C.J.
Old 04-08-2001, 06:39 AM
84w44s's Avatar
84w44s
84w44s is offline
here's your codes,
first position
(decade)
b=1950-59
c=1960-69
d=1970-79
e=1980-89
f=1990-99
second position
(year of decade)
c9ae-would be a 1969 and so on.
third
(car line)
a=ford
d=falcon
g=comet, montego, cyclone
j=marine and industrial
k=edsel
m=mercury
o=fairlane, torino
s=t-bird
t=truck
v=lincoln
w=cougar
z=mustang
fourth position
(engineering group)
a=chassis
b=body
e=engine
the fifth letter after the hyphen, typically means the change level. the letter "a" usually means original status of the part. "b" would indicate at least one engineering change. ford used the entire alphabet for this, except for the letter "i", when the alphabet runs out, it starts over again at "aa", "ab", "ac" and so on
> Intake Manifold #:
> C9AE-9425-A
> Head #:
> C8VE-E
your heads would be 1968 429 from a lincoln engine.
every part on your engine will have a code on it. if you stand in front of your engine, on the left side of the block down behing the exhaust manifold will be the block code.
icecold
08-17-2015 12:12 PM
broncorif
03-23-2010 06:20 PM
78longbed
05-23-2007 07:14 PM
JoeKnows89
04-04-2005 02:08 PM
Quick Reply: code readers needed!
