Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-06-2008, 03:03 PM
hoxiii's Avatar
hoxiii is gaining momentum as a positive member of FTE.
86 F-150, wanting quiet as can be
Allright, I have a 1986 F-150 300-6 that is about due up for a muffler. It's been rusted at the inlet since i bought the truck a couple months ago, but it's putt, putt, putt at idle is starting to pop and rumble now.
What I'm looking for is what the title says. I want this truck as quiet as can be within a reasonable budget. I'll be honest, i've never had a truck with a totally intact stock muffler so I don't know how quiet one is stock. I don't care about tone, i don't care about presence. I want quiet.
Is my best bet a stock round body replacement or is there something just as quiet in a similar price range out there ($50ish).
For packaging reasons a small body muffler like a 30 or 36" glasspack would be nice, but i don't want the glasspack noise.
Justin
__________________
86 150 SuperCab Shortbed 4x4 conversion XLT Lariat, 300, 435
85 150 4x4 convert, 390 FE, NP435, 205, 9" TTB 44
R.I.P 8-26-07
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=161169&.jpg
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-06-2008, 03:51 PM
73f100shortbed's Avatar
That's how we roll
73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold
Just go with a stock muffler
__________________
Sean
Tim's Minions - Resident BEEFCAKE!
1973 F100: 302, 3-speed, Hurst shifter, headers, dual exhaust
Member of the New Jersey Chapter
For Sale!
  #3 (permalink)
Old 02-06-2008, 05:11 PM
phoneman91 is starting off with a positive reputation.
Yeah--a stock muffer and behind that--install a resonator--like on the luxury cars.
__________________
92 F150 XLT 4x4 regular cab/short box.5.0 V8,5sp trans ,108k miles-- on synthetic oil. Trailering/Handling option(stabilizer bars front /rear and quad shocks).Factory skid plates,manual hubs, manual transfercase, Super Cooling.4.09/4.10LS.31'' tires. 20.3 MPG @ 60 MPH.4350 lbs with full tank of gas!!
  #4 (permalink)
Old 02-06-2008, 06:57 PM
jimbo beam's Avatar
jimbo beam has a great reputation on FTE.jimbo beam has a great reputation on FTE.jimbo beam has a great reputation on FTE.jimbo beam has a great reputation on FTE.jimbo beam has a great reputation on FTE.
For a while I had two 34 inch glasspacks behind the 300 in my 82. My factory exhaust fell off at the manifold downpipe. I clamped the two packs together, and then clamped them to the downpipe. They were long enough that the exhaust dumped right after the cab, it was pretty quiet.
Once I got some money saved up I bought a section of pipe to bolt to the downpipe, I then used the factory canister muffler and tail pipe that came off my 96 when I put duals on it. With the canister muffler it was extremely quiet, couldn't be heard unless I lowered my head within a foot or so of the tailpipe.
If you willing to spend the dough for one a factory canister style muffler would be the best choice. If you were closer I'd glady give you the one I cut off my 86.
__________________
MAT
82 F100, 460/C6 4.10. In pieces slowly undergoing a
restoration.
86 F150, 351HO/C6 3.73. Holly 650 - Weiand intake
Ported E7s - Comp X cam - Hooker long tubes
Thrush glasspacks - no cats - B&M shift kit - Tru Track
locker. The daily driver, work truck, and rat rod.
96 F150, 302/E4OD 3.55LS. My 50,000 mile original gem
  #5 (permalink)
Old 02-06-2008, 07:39 PM
hoxiii's Avatar
I'm looking at the OE cansiter style right, at $100 it's more than i wanted to spend *right now* but it'll beat buying the $50 "one year" canister muffler that'll rot out in 13 months to the day and have to be replaced again.
Justin
__________________
R.I.P 8-26-07
  #6 (permalink)
Old 02-08-2008, 01:28 PM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
http://www.cherrybomb.com/vortex-mufflers.html Get one of the two output ones
and split it to each side half the noise to each side. A cat convertor always keeps
a motor quiet. If yours was gutted or removed it will definately quiet it down. I wish
I left mine stock sometimes like when out trail running looking for animals or when
out wheeling and near some houses that got built near many of my old trails.
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #7 (permalink)
Old 02-08-2008, 02:23 PM
hoxiii's Avatar
I'm really thinking 2.5" glasspack inline with a stock muffler. the glasspack would act as a pre-muffler and resonator to a point, and then the stock muffler would really shut it up. running the 2.5" on a 2.25" system also shouldn't create much of a restriction prior to the plug of a stock muffler.
Justin
__________________
R.I.P 8-26-07
  #8 (permalink)
Old 02-09-2008, 04:56 PM
blue beast's Avatar
Avacuum gauge connected to your motor will tell you if the exhaust changes make
any difference in regards to restriction. It really takes alot to give a restriction that
will cause a big performance drop unless you are on the drag strip!!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
