Check this out, 0-60 MPH calculator.
Old 02-06-2008, 01:53 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
02GrayPowerStroke is offline
I did a reverse enginering, I put in the HP and 6600 LBS until I got my 0-60 time that I got from my Gtech. Came up with 450HP, with a 0-60 of 6.5 secs. Do that Hp number seam high?
http://www.060calculator.com/
Old 02-06-2008, 02:00 PM
ggirten's Avatar
ggirten
ggirten is offline
6600 Pounds? My 99 F250 is over closer to 9000 and my sons 2000 F350 is higher than that.
Old 02-06-2008, 02:04 PM
02GrayPowerStroke
You are at looking Gross, and that is 9K. Add the max load and you get around 9K
Old 02-06-2008, 02:15 PM
02GrayPowerStroke
Based on 9K I have 500+ horsepower. Dont think thats right.
Old 02-06-2008, 02:35 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
a 350 dually 4x4 may be close to 9000 lb,mine was about 8400 before topper and tools
Old 02-06-2008, 02:39 PM
wlihntr's Avatar
wlihntr
wlihntr is offline
there is no way your truck is 6600 lbs on the hoof. the last time i weighed mine with no one in the truck and about half of tank of fuel it was 7910. which then leads my to believe either you G-tech is off or the formula you are using is not correct
Old 02-06-2008, 04:02 PM
eatfish's Avatar
eatfish
eatfish is offline
I wouldn't trust the calculator... It doesn't take into account for gear ratio or tire size.
Old 02-06-2008, 04:17 PM
02GrayPowerStroke
read this, then do your own search.
http://www.automotive.com/2002/43/fo...ons/index.html
Old 02-06-2008, 04:58 PM
HKusp's Avatar
HKusp
HKusp is offline
I was on the scales a few weeks ago at the dump and empty I was 8130lbs. Thats with me in it and I am 240lbs not much in the bed, maybe 150lbs max and my snow plow frame on the front, maybe another 175 or so. I am a crew cab 250 4wd short bed. So I would think that a dually would be pushing 9k very easily with a cap and or tools and tool boxes. That dually axle alone is a beast, not to mention the wheels and tires.
Old 02-06-2008, 05:00 PM
HKusp's Avatar
HKusp
HKusp is offline
I promise you that 5500 curb weight is a mistake.
Old 02-06-2008, 05:27 PM
lukecline's Avatar
lukecline
lukecline is offline
Your about 175rwhp short of 450 with your mods. Your weight is also a touch low. My cc 4x4 tips the scales at 8000lbs w/o a whole lot of tools in it.
Old 02-06-2008, 05:30 PM
lukecline's Avatar
lukecline
[QUOTE=02GrayPowerStroke]read this, then do your own search.
http://www.automotive.com/2002/43/ford/f-250/reviews/summary-specifications/index.html[/QUOTE]
The truck listed on that page has to be a gasser due to the hp/ tq ratings.
640 CI Aluminum FORD
2017+ Super Duty
15
05-23-2017 07:37 AM
Homerunking2394
1999 to 2016 Super Duty
24
11-07-2016 09:55 AM
Reaver75
6.2L V8
24
11-09-2010 10:33 AM
iamme81702
10-15-2010 02:39 PM
IDIDieselJohn
27
11-08-2009 09:51 PM
Quick Reply: Check this out, 0-60 MPH calculator.
