marine 460 - Ford Truck Enthusiasts Forums
marine 460
Old 04-07-2001, 06:25 PM
tbolt 460's Avatar
tbolt 460 tbolt 460 is offline
tbolt 460 is starting off with a positive reputation.
marine 460
are there any internal differences between the car-truck,and marine 460.I heard the marine on has a steel crank,CJ rods,different pistons.I cant find any info on the marine ones.These engines are in a cabin cruiser and ran last yr.They are earley 70's 460's.I get the # tomorrow
Old 04-09-2001, 07:25 AM
dre dre is offline
dre is starting off with a positive reputation.
marine 460
Most all Marine engines are built with heavy-duty internals
to withstand High RPM runnings.
The cams are profiled for top end, as opposed to low end Torque.
The Head gaskets and Freeze plugs are usually brass to guard
against salt water corrosion, And the intake system uses
Air Arrestors for air filters. Distributors have arrestors also.
This is to prevent sparks.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old 04-10-2001, 06:21 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
marine 460
A marine 460 will have the truck/CJ rods. They will have a cast crank not steel. The marine cam is designed for low to mid RPM HP and torque usage...a more radical cam will draw water into the exhaust ports causing engine damage. Most marine engines other than outboards are designed to run a maximum of 4,400-4,800 RPM for extended periods under high loads. They do use brass freeze plugs and will have brass in other critical areas to help prevent corrosion. I believe the Mericruiser 460's are rated at 335 HP.
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old 04-10-2001, 12:53 PM
TBirdGuy TBirdGuy is offline
TBirdGuy is starting off with a positive reputation.
marine 460
I'm not sure the specific times that they were used, but some marine engines are reverse rotation. That's no big deal, only have to change the cam and distributor to switch back to normal rotation.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Old 04-10-2001, 01:00 PM
marine 460
351W marine mudrunner4ever Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 14 10-06-2011 04:26 PM
marine 460 with DO0E heads/intake whd507 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 04-01-2005 09:55 AM
Marine 460's? Bubba Blue Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 01-24-2005 03:23 PM
460 marine engines paulm Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 01-11-2005 06:53 AM
marine 302 tbolt 460 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 06-06-2001 01:29 AM
Tags
460, cam, marine, radical
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
