Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 02-09-2008, 04:50 PM
250turbo is starting off with a positive reputation.
don't think tranny will bolt up.
__________________
'96 f250 h.d. p.s.d. super cab,long bed,e40d with cOOnhunterjoe trans mod.gutted ebpv,3x4 d.p. & 4" exhaust,gauges,ab injectors,tranny& inter coolers,ex. brake,ccv mod,130 gallons motion lotion,fs2500 by pass,certifed j b welder
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 02-09-2008, 05:55 PM
mnmwhit is starting off with a positive reputation.
ford makes a 4.5 liter diesel for commercial class 5-6 trucks. Good motor.
You could get one of those out of the box and work through making it fit/bolt up.
Revs slow but has good torque. And great fuel economy. There is a company up here that runs a few of these trucks and one of them has 300K miles on it and the driver told me you can't tell a difference between that one and a new one. They use them for parcel delivery between Fairbanks and Anchorage.
__________________
Max W
06 F-350 4X4 6.0 PSD NORTH POLE, ALASKA
Mobil-1 5-40 turbo diesel truck oil from day #1
98 gallon transfer flow tank
Leer topper insulated
MBRP SS409 turbo back Off-Road duel exhaust-CAT IS GONE
AstroStart 2-way Auto start
Go Rhino pushbar/brushguard,4-9" Lite-Force moose lites
  #18 (permalink)
Old 02-09-2008, 05:57 PM
does the weight matter? He is putting it in a F-250. Ford puts the 6.0 in the 250 I don't know if they put different springs in or not.
Quote:
Originally Posted by tex25025
I think the 5.4 is round 520 and the powerstroke(atleast the 6.0) is round 1,062.
__________________
Max W
  #19 (permalink)
Old 02-09-2008, 07:14 PM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
Quote:
The OP asked for the weights because he wanted to know what the difference was(post #8), I responded to that question.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #20 (permalink)
Old 02-09-2008, 10:11 PM
RunRed is starting off with a positive reputation.
Quote:
Originally Posted by nevrenufhp
A DT360 is easy to find, it depends on where you look. The ones I see go for around 1500. Try Larry at www.valtruck.com , he's trying to get rid of Ford 6.6's & DT360's because nobody wants em.
I don't understand that. The DT360 is the same dimensions as the cummins 5.9 (almost) and I have read all over the place that they can be turned up as far as the cummins and hold up even better. I just don't see why nobody is taking them. Hmm.
__________________
1990 F250 7.3 IDI NA E4OD 4x4 250k
1997 2500 Cummins 12V 2wd NV4500 290k
  #21 (permalink)
Old 02-09-2008, 10:25 PM
LilredWagon is starting off with a positive reputation.
In response to post #18, even though Ford called it an F-250, the '98 F-250 light duty was really just a beefier 150. it only has a 7700# GVW where the Superduty's are over 8500#. So, sticking a 1000lb powerstroke plus all of the necessary components to run it on the front wouldn't be too good of an idea, but the Cummins 4BTweighing in at 750 lbs might be a feasible option. Plus, I found a website where they converted an F-150 over to a Cummins 4BT, though they don't include any literature on how they did it.
http://automotivesolutionsraleigh.co...onversion.html
  #22 (permalink)
Old 02-10-2008, 10:59 AM
nevrenufhp is starting off with a positive reputation.
Quote:
The dt360 is about a half inch longer than the Cummins, but ya, it's pretty much the same. Th dt360 is like an unsung hero. Sled pullers have used them for years, and made 1200+hp long before Maddog did with his 6BT. They can take that power for a longer duration than the 6BT, which makes them a great sled puller. Shoot, you can even wind a DT466 up to 4500rpm, not that you would need to on the street, but gives you an idea of how overbuilt the IH engines are. My work truck (1994 DT466)almost hits 3100rpm now. It's on youtube.
__________________
turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, heddder.
Project: 99 Stupor Duty F250, 2WD, AT545, waiting for DT466(IH power)
  #23 (permalink)
Old 02-10-2008, 11:40 AM
royzell is starting off with a positive reputation.
Hi, 'just my $.02, I think in the F-150 the weight of a navistar/cummins-dodge/GM diesel is too much for the suspension. That is why (at least in the beginning) Ford went heavy duty on the F-250 with a straight axle and leafs, I like those small cummins engines, but really have to speak up for the five cylinder Mercedes turbo diesels. (about 1981-1985 in cars). A junk or rusty car (300D or 300SD) can be picked up cheap. We have had several of these and in a 4000 lb car consistently get mileage in the mid-high 20's, city or highway, slow or fast. Mods are simple because the engines are simple - no computer. The hp is 120 stock, I can't remember the torque #. For a truck you would probably want to source a different tranny.
My wife currently drives a nice '84 300SD, I just bought a rusty but good running parts car for $400.
Good Luck !
__________________
88 F-250 ext cab, 7.3, C-6, 3:55, 4WD, aftermarket modified powerstroke turbo with intercooler
84 Mercedes 300SD turbo-diesel(parts car also)
93 Honda Accord
77 Chev Class C Motorhome
and other rusty or rugged parts vehicles...
  #24 (permalink)
Old 02-10-2008, 11:44 AM
whoops ! I didn't see that you have an F-250, weight may be not as much of an issue. I still like the MB though.
__________________
93 Honda Accord
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
