I found a oil pan...will it work?
Dan, sorry i read your post too fast the first time, i actually used an 83 pan on a 73 block. but to answer your question, the bolt pattern is for sure the same and i would think that the shape of the pan is the same too...one thought, could the newer pans have an oil level sensor in the pan? i know a lot of the newer stuff started using those. but like i said, thats just a guess, i have no experience with the 90's big blocks.
oh also, call me a cheap-skate but i didnt bother with the bolt that holds down the pickup tube, i just bent the bracket up a bit so that there was no strain on it as it rested on the flat bolt. of course i checked to make sure it was solid, which it was, and i cant forsee having any problems with it. =)
Yea, you can use it but you'll need the longer, bolt on rear sump pick-up tube and the truck oil pump. You can get the whole kit from Jegs or Summit Racing. Get the Melling 689-M84DHV oil pump from Jegs and the Ford Motorsports rear sump oil pan kit. Pan kit is $180 and the pump is $75.
Hope this helps
Hope this helps
Dan Biehl
11-29-2014 11:23 AM
Chuky66
04-24-2004 09:52 PM
bigblue
05-21-2003 03:18 PM
