96 350 psd fuel leak
just wondering if anybody has dealt with this before. small amount of fuel on top of engine under fuel filter. cleaned it up flashed truck up and looked for almost an hour and could not find anything. maybe it leaks at higher rpm. starter roles over a little more then it should to start thinking im lossing prime. i would appreciate any ideas before i start pulling filter houseing and lines. first time on this site so hello and thanks to anyone who might answer.
Hey Islander,
I have had several issues with fuel leaks on my truck. The most recent one I found by having my wife rev the engine up while I used an inspection mirror to try and find where it was coming from. This trick worked, it is leaking from the heater element (might be calling it wrong name) that is just above the fuel line at the base of the fuel bowl.
Only noticeable when the engine is reved up.
Craig
Craig
artfd
01-01-2012 08:13 PM
