Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-05-2008, 09:42 PM
73F100*8Mile is starting off with a positive reputation.
FE Manual Trans--> Which one?
I grew up working on/rebuilding ford automatics so I don't know jack about the manual trans offered out there. What all will mate up to a FE? If I can find a 4spd of some sort then I'm gonna put a 390 in my fairlane b/c I really want that o/d gear. Is T4 one of them? The 390 won't be sluggish either so the trans will have to stand up to some power.
__________________
1973 F100 390 C6 2.75 gears
1990 Honda Accord
1967 Fastback S code 390- sold
1968 Hardtop Mustang I6 200
1977 E-150 351w
1968 Fairlane 289
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-05-2008, 10:54 PM
dodmort's Avatar
dodmort is starting off with a positive reputation.
i have np 435 and t-18s up to fe s now but i dont think that is what you are building..does not sound like you are doing a truck??
__________________
24 t (not a sreet rod)
67 gt500 (3rd one)
68 bronco
69 f-250
72 bronco
97 f-350
98 svt cobra
01 hd road king
06 exped.
68 m715-fe,powered - 4 link
Rather have a bottle in front of me than a frontal lobotomy
  #3 (permalink)
Old 02-05-2008, 11:04 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
A toploader is the only thing to put in your Fairlane behind your 390. It will fit because they came in those cars behind the FE motors. The are bullet proof too.
__________________
Bear 45/70
Gimp Racing
  #4 (permalink)
Old 02-05-2008, 11:15 PM
Now where can I get one? How do ya'll feel about reman'd tranny's? What all year/models did the toploader come in?
__________________
1990 Honda Accord
1977 E-150 351w
1968 Fairlane 289
  #5 (permalink)
Old 02-05-2008, 11:20 PM
Bear 45/70's Avatar
Quote:
They came at least in the 1966 thru 1969 or 70 Fairlanes, Torinos, Mustangs, Cobras, Cougers, Cyclones with FE's in them. Plus other models in the Ford line.
__________________
Bear 45/70
Gimp Racing
  #6 (permalink)
Old 02-05-2008, 11:22 PM
forgive my ignorance,--Can I just get any T4 and then get a FE bell? I'm seeing that there is a close and wide gear ratio, what would be best for my fairlane? It's got 3.00 gears in it now so I guess I can go to a lower gear.
__________________
1990 Honda Accord
1977 E-150 351w
1968 Fairlane 289
  #7 (permalink)
Old 02-05-2008, 11:23 PM
Putt's Avatar
Putt is starting off with a positive reputation.
If you are wanting an overdrive gear, the standard Top Loaders do NOT have one.
__________________
Putt
1966 F100 4X2 428 4 and 3 sp. 2.75:1 rear
1989 F250 Super cab 351 4X4
1965 Mustang coupe w/289 2bl.
  #8 (permalink)
Old 02-05-2008, 11:24 PM
Putt's Avatar
T4??? I have heard T5, T10, T56, but not T4.
__________________
Putt
  #9 (permalink)
Old 02-05-2008, 11:26 PM
Well don't let my stupidity surprise you Putt. I don't know what I'm talkin about, thats why I'm askin you boys.
__________________
1990 Honda Accord
1977 E-150 351w
1968 Fairlane 289
  #10 (permalink)
Old 02-05-2008, 11:39 PM
Putt's Avatar
HAHA!! OK, the Top Loader is just that.. a Top Loader, originally they were used in "performance" cars. I have one in my '66 F100 now. The T# is/was used by Borg Warner for their tranny ID. The close ratio/ wide ratio mainly refers to first and second gear in the trans. Google David Kee Top Loader and search around there a bit for more info than you will likely want to digest. Close means less RPM drop between shifts, but not as low a first gear for starting out. Wide gives more RPM drop between 1 and 2, but a lower first gear for starting out. You will likely need a rear gear around 3.5:1, 3.7:1 or so with either option for decent acceleration.Neither of the first gear ratios is very low compared to a "truck" trans.
HTH
Hi, Bear! We should be able to help him out! Spend his money$$$$
__________________
Putt
  #11 (permalink)
Old 02-05-2008, 11:40 PM
Bear 45/70's Avatar
With 3.00 gears you want the wide ratio. I ran a close ratio with a 3.00 rear for a while way back when and 1st gear would do 60 mph at redline. With 3.91s or 4.30s in the rear the close ratio is a killer off the line. With real good tires or slicks you can lift front wheels. Gear wise it's what the 428SCJ Drag Packs ran for gears.
__________________
Bear 45/70
Gimp Racing
  #12 (permalink)
Old 02-06-2008, 12:22 AM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
http://www.4speedtoploaders.com/
There is another site, just google "toploader 4 speed"
Not sure what a T4 is, never heard of that.
Forget Borg Warner T10 unless you buy a new one if you can even find that.
You want to run 3.91 or 4.30 gears, an od would come in handy. See the "ID Charts", "toploader imposters". There is an od trans, but it would suck big time.
1st and 2nd ok, huge gap 2nd to 3rd, and if you leaned on 4th it would probably break. (although at least one guy here has one behind a 390....)
$1000 or so for the toploader with all the new stuff and which won't pop out of gear on you, see the site.
$3000 for a GearVendor overdrive to bolt to the back of it.
http://www.gearvendors.com/
You don't want to be cheap now, do you?
Or get a T56 or TKO
http://www.ttcautomotive.com/English/products/TKO.asp
  #13 (permalink)
Old 02-06-2008, 01:10 AM
Raider50 is starting off with a positive reputation.
ok while we are on manual transmissions that fit behind 390's dose anyone know of a race/high performance tranny to go into a 4x4 76' f150? any input is useful im still trying to learn about 390's and what goes with them. Thanks
  #14 (permalink)
Old 02-06-2008, 09:03 AM
Freightrain's Avatar
Freightrain is gaining momentum as a positive member of FTE.
A wide ratio toploader has 2.78 first gear, the close ratio is 2.32. Unless you run a bunch of rear gear, the close ratio is like starting out in second gear all the time. It's a great road racing tranny, as 1st gear is usable at good speed.
__________________
1967 F100 352/4spd
1969 F100 428CJ/4 spd
64 Galaxie with blown 390 4 spd
64 Galaxie wagon with 428 5 spd
2006 UMTR POWERSHIFT
POINTS CHAMPION
  #15 (permalink)
Old 02-06-2008, 09:50 AM
royalchoppers is starting off with a positive reputation.
Ahhhh, the great tranny delima. This conversation sounds familiar.
__________________
In 4130 we trust.
www.myspace.com/royalchoppers
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
