H9 axle code - Ford Truck Enthusiasts Forums
H9 axle code
Old 02-05-2008, 07:15 PM
jsgoss02 jsgoss02 is offline
jsgoss02 is starting off with a positive reputation.
H9 axle code
Wanted to throw this out there and see what other's think. My code on the door panel for the axle reads H9. H9 code indicates the rear differential should be a 3.55 Limited Slip. Now, this is a 92 Ford F150, 4x4, E4OD, and 5.8 EFI engine. I really believe that the original rear differential may have been removed. This is why I think this. At 55mph, the rpms are 1600. I could be wrong, but I would've thought that 3.55's would turn more rpms at this speed. The wheels are 31's. Also, one back wheel will spin by itself in the back. Would not both wheels spin with limited slip? What do you guys think? Thanks.
Old 02-05-2008, 07:20 PM
cjg1999 cjg1999 is offline
cjg1999 is starting off with a positive reputation.
1600 rpm could be a result of the E4OD as it has a good OD gear. Also with the one wheel spin, if the truck has a lot of miles, the locker could be worn out and need of a rebuild. The way you can tell is on the back cover of the rear there should be a tag, if it still a 3.55 locker, it should say 3L55 and some other numbers. Take a look and see if its there, good luck!
Old 02-05-2008, 07:52 PM
Fordman_Evs Fordman_Evs is offline
Fordman_Evs is starting off with a positive reputation.
H9 is 3.55LS I turn about 2000rpm at 60mph... so that seems about right. The overdrive on my 5 speed is .79.
Old 02-05-2008, 07:57 PM
THE KING THE KING is offline
THE KING is starting off with a positive reputation.
Wow, What RPM's do you run at 70? Im at 2 grand at 72 MPH... Bout 1700 at 60, 1400-1500 at 55
Old 02-05-2008, 08:34 PM
Quote:
About 2500 rpm at 70mph.
Old 02-05-2008, 08:52 PM
you have a manual but is that when your in OD?
Old 02-05-2008, 08:56 PM
Thats some high R's, my truck SUCKS the gas anything over 2 grand.
Old 02-05-2008, 11:36 PM
Surge08's Avatar
Surge08 Surge08 is offline
Surge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to behold
I turn about the same with a AOD and a 5.0L
Old 02-05-2008, 11:38 PM
Surge08's Avatar
There is something wrong with that man. it shouldn't be that high
Old 02-05-2008, 11:41 PM
Yeah my truck likes the gas and yes that is in 5th (OD)...and I still want 4.10's.
Old 02-05-2008, 11:43 PM
Quote:
I installed the tach from another cluster maybe I screwed up but I don't think so. I'm going to double check those figures tomorrow on the way to work.
Old 02-05-2008, 11:56 PM
Surge08's Avatar
oh ok that may make some sense
Old 02-06-2008, 08:50 AM
lol i didnt want to be the bear of bad news lol. Even tho its a manual i would think it should be around 2 still, if not i wouldnt want that gas bill.....
Old 02-06-2008, 11:13 AM
tfowler306's Avatar
tfowler306 tfowler306 is offline
tfowler306 is starting off with a positive reputation.
Quote:
My 1990 5.8 has 3.55 gears and when it did have an E40D I was running right were you are. also with 31x10.50s.
now with my 5 speed I am running 2400 at 70 and 1500 at 45. 5th gear is a .84.
Old 02-06-2008, 11:15 AM
tfowler306's Avatar
my 90 E40D had a .68 OD.
1993 Axle code H9B ncranchero 1987 - 1996 F150 & Larger F-Series Trucks 15 02-17-2013 09:00 AM
Can I replace rear axle H9 with a H19? ruffneck30 1997 - 2003 F150 1 06-24-2011 10:18 PM
2010 F150 front and rear axle driptorch970 2009 - 2014 F150 1 12-16-2010 04:00 PM
Rear Axle Ratio thiggy 1997 - 2003 F150 4 10-14-2010 03:04 PM
rear end axle code.....h9 z 97ford1 1997 - 2003 F150 6 09-08-2006 04:14 PM
Tags
05, 1990, 1996, 2000, 2006, axle, code, codes, codre, diff, end, f150, ford, h9, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
