Just got her, want to make sure she's a 460
Hey guys,
I just picked up a 71 with a transplanted 460, power steering and power brakes. I wanted to know where the serial numbers are on the block and heads? I just want to make sure it is a 460 and try to find out what year it is. Once I get the numbers, what can I reference then to.
Thanks
Austin
Thanks
Austin
The block's casting numbers are on the passenger side of the block, just behind the starter. Look for numbers like D1VE, DOVE & 6015.
The heads casting numbers for a 429-460 are located just above the exhaust manifold's and just below the valve cover gasket rail, look for at least a four digit code, C8VE, C9VE, DOVE-C and etc. When you do find your casting #'s come back here & post them, someone will be able to give you more info on your engine, if in fact it is a 460.
Todd
BB79RANCH
Todd
BB79RANCH
If its BIG and BLUE its a 460!!!
[font color=blue] [b] [u]77 Ford F-150 Explorer
[ul]
[li]460 big block(stock)
[li]P275 60R 15 tires
[li]Jensen CD player with 2 Pioneer 180 watt 6.5 inch door speakers and 4 other speakers behind seat
[li]Flomaster 40-Series mufflers
[li]3 inch aluminum pipe with 4 inch stainless steel tips
[li]14 inch Edelbrock chrome air cleaner[/ul]
[ul]
Bigblockbennett
05-16-2022 04:50 AM
martion
09-05-2010 03:53 PM
OldFords
55
03-03-2009 01:12 PM
