Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 02-05-2008, 05:54 PM
slrassoc slrassoc is offline
Garage is empty, add now
slrassoc is starting off with a positive reputation.
2001 Ford Ranger Ball Joints
Need someone to converse with with respect to changing out the lower ball joints on my 2001 Ranger 2wd pickup. Please email me at slrassoc@yahoo.com and I will give phone number. Have a few questions. Someone that has actually does this before please.
  #2 (permalink)
Old 02-06-2008, 01:12 AM
CougarXR02 CougarXR02 is offline
CougarXR02 is starting off with a positive reputation.
2wd with coil springs or torsion bars?
  #3 (permalink)
Old 02-06-2008, 03:19 PM
Ranger 2wd 2001 ranger ball joints
It has coil spring suspension.
  #4 (permalink)
Old 02-07-2008, 02:33 AM
It's pretty straightforward. You will need the C-clamp style ball joint press available as a free loaner (when you leave a security deposit) at most chain stores (autozone, advance, etc.). Once tire's off, undue the cotter pin and retaining nut. Use a ball joint separater (pickle Fork) to pop apart. Pop out the retainer ring on the bottom. Follow instructions to use the clamp press, and press the old one out. Reverse for install.
  #5 (permalink)
Old 02-07-2008, 06:03 AM
We got that far but the problem is that once the castle nut is off the ball joint, the bottom part of the steering nuckle...the part where the ball joint stem mounted into...is right under the control arm and it is in the way so there is not enough room to press the ball joint down and out. How do you move that bottom part of the steering nuckle out of the way???
  #6 (permalink)
Old 02-07-2008, 07:08 AM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
BJs are one weekend deal on 2wd ranger. I advice you to be carefull eith springs uscrewing lower BJ, because spring extracts with dangerouse for your hand force. Use small additional hydravric jack.... Nock lower BJ out with hummer.....
  #7 (permalink)
Old 02-07-2008, 11:43 PM
If I remember correctly I popped off the Tie rod end, and Sway bar end link. This allowed the whole spindle assembly to swing forward, hanging from the upper ball joint. For the price, it's a good time to just replace the sway bar links, and even the tie rod ends. Links are about $18 per side with urethane bushings. Tie rod end I wanna say was under $30. Finish all, and get it aligned one time.
  #8 (permalink)
Old 02-10-2008, 01:39 PM
That did it. Poping out the tie rod end gave me the room to press out the ball joint. Now everything is tight. No side play or top to bottom play in the tire. There is just a slight amount of play on the other tire so I think I will replace that lower ball joint also. The top ball joints feel just fine. That's good cause I can't for the life of me figure out how they are held onto the upper control arm. There is no keeper ring. No bolts. No welds etc.
  #9 (permalink)
Old 02-10-2008, 02:44 PM
Peter94's Avatar
Peter94 Peter94 is offline
Peter94 is gaining momentum as a positive member of FTE.Peter94 is gaining momentum as a positive member of FTE.
I dont remember which years but some you need to buy the whole control arm for the uppers.
__________________
2004 F150 FX4 Crew Cab
85 4x4 5.0L F150 Reg Cab-What the heck should I do with this thing?
  #10 (permalink)
Old 02-10-2008, 02:57 PM
Glad it worked out for ya! I hate to see people pay full price for things like that, That they can handle themselves. It might not be a bad Idea to do that other lower now, if you are able. I like to do them in pairs. Especially if you already have the press borrowed/rented. But I know not everyone has the $$$ around.
As for the uppers, my 99 I had to do control arms. They cost $67 each, but it made them sooooooo easy to replace. Just the main nut and cotter pin on the ball joint to spindle, and the 2 bolts on the frame. No special tools needed.
  #11 (permalink)
Old 02-10-2008, 07:06 PM
Greg R's Avatar
Greg R Greg R is offline
Greg R is starting off with a positive reputation.
The '98-up 2WDs with coils have replacable upper ball joints, torsion bar Rangers need the whole arm replaced.
__________________
98 Ranger 2WD - 4.6 dohc, Ford prototype intake, custom headers, 4R70W trans, 8.8/4.10/TL, aluminum drive shaft, Lakewood traction bars,Mark VIII guages, Explorer buckets, rear auxiliary fuel tank (no midship), relocated fuel door
http://281ranger.homestead.com
http://www.cardomain.com/ride/2052265
  #12 (permalink)
Old 02-17-2008, 07:23 AM
2001 Ranger ball joints
Yes you can buy the upper ball joints for my 2001 Ranger and don't have to replace the control arms. You can also buy the control arm with the ball joint already installed in the control arm. That might be the easier way to go. Was wondering...if you remove the bolt and nut on the ball joint and remove the two bolts on the control arm, will the whole assembly just lift out or do you need to dissconnect the lower ball joint in order to have room to pull off the upper control arm and ball joint? I don't think it woul make any difference if I changed the uppers cause after I changed the lowers there is no play in any direction on the tires. Everythinh is tight.
  #13 (permalink)
Old 02-17-2008, 11:02 AM
I had to wait for one to get ordered, so the uppers got installed a week later than my lowers. and I did not have to take off the lower at all to do the upper.
I know on my uppers, the bushings in the control arm were creaking and the tires definately cambered in at top. Went the whole control arm route because it fixed it all at once.
Twice I got ball joints listed as replacements for the uppers. and they looked way different, and when I went back it was because they were for different setup. Whether 4x4, torsion. I don't know.
  #14 (permalink)
Old 02-17-2008, 11:31 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Dont forget to get an alignment if you move the top one
  #15 (permalink)
Old 02-17-2008, 09:36 PM
X2. I think it was mentioned earlier, but def. don't forget it within a few days or so after finishing.
Tags
2000, 2001, 2002, ball, ford, grade, joint, joints, lower, professional, ranger, removing, replace, replacement, replacing, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
