ticking
ticking
Another question about the 460. Is the ticking sound normal? I have heard that all the electronic ignitions make that sound. I just put in a new engine and it has 2000 miles on it. I don't remember the sound at first. My fear comes from the last engine I had that blew a rod when the ticking turned into clacking. It is a 1984 and who knows how many miles that engine had on it but I really don't want to go through that again.
Eric
Eric
ticking
Also may check oil becuase that can sometimes make a sound sort of like that. But if its not that its gotta be an exhuast leak.
1985 "Cowboy Cadillac" Ford F-250 4x4, Granny 4-speed, 4:10 Gears, 460 with Holley 750cfm 4-barrel Carb, Custom Painted Block (Ford Dark Blue), Rebuilt Transfer Case, BFG Trac-Edges, Tachometer, Kenwood CD Player and Pioneer Speakers, 27" cherry bombs dualed out each side with 2 1/2 inch pipe, NAPA Premium Clutch, NAPA Premium timing Chain, Gooseneck Ball, Hitch Reciever, Whistler 400 radar detector!
"When in Doubt GAS it"
ticking
I had the same problem with a 514, the sound was coming from the header flange gaskets. Unlike most engines where the gasket is symmetrical (installs either way), these engine's manifold gaskets can only be installed one way. If you put 'em on backwards (like I did) they will be misaligned, only about a 16th of an inch, but just enough to create a "ticking" sound. Just my $.02
roverjoe
1999 to 2016 Super Duty
04-22-2010 05:15 PM
88Ford
Modular V10 (6.8l)
07-25-2006 10:42 PM
SCWIDVICIOUS
06-30-2006 05:44 PM
LimeyZ
07-07-2004 01:49 AM
