79 f250 brake problem
ok i bled all 4 corners today and my pedal is still squishy, bled em till it ran clear it sounds like an air leak when you depress the brake pedal and it doesnt get frim till 3/4 way down.
now would this likely be the M/C or booster or both?> it's a 4x4 dual piston vin is sneg4150 if i need a new booster i am gonna upgrade it to bendix R2512681 from a 79 f350
look if your one of the high and mighty look at my internet ***** kinda guys wonderfull just what we need
i intentionally spelled it wrong as in find the way to the problem ie. route this truck is pushing 30 and i imagine the brake stuff is original except for what i have already changed out.
now if you dont have helpfull information for my problem click on your browsers back button and read someone elses post.
on
There is a rod in the booster that depresses the master cylinder.
It has an adjusting nut on it.
Turn it out a few turns and try it.
The measurment from the face of the booster to the end of the rod is about 1".
Don't go to far or the brakes will hang up and wear out quicker.
This is after the rear shoes have been adjusted.
