Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-05-2008, 04:32 PM
mollikate mollikate is offline
mollikate is starting off with a positive reputation.
Skipping
I went on a short run this morning with light load. When i got there my truck was skipping so i pulled codes. got a 236 which i always get. When i started it back up there was no skipping and it run fine. By the time i got back home it was skipping again. Restarted and it ran fine again.
thanks
  #2 (permalink)
Old 02-05-2008, 04:36 PM
Alpine6 Alpine6 is online now
Alpine6 is starting off with a positive reputation.
I would suspect a UVC harness issue. I can't remember what the 236 code is, but someone will chime in!
__________________
Matt
1999.5 F350 CC
MODS: DP Tuner, BTS Trans, ITP Regulated Return, Ceramic Up Pipes, ITP Intank/HPX, aFe Stg II, 5" Cannon Exhaust, and some other stuff.
  #3 (permalink)
Old 02-06-2008, 08:01 AM
Aparantly No One Is Going To But Thanks I Will Check It
  #4 (permalink)
Old 02-06-2008, 08:55 AM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation.
P0236 Turbo Boost Sensor A Circuit Performance
Do you have a chip/tuner?
  • DTC P0236 indicates a turbo boost sensor A circuit performance concern.
  • DTC P1247 or P1248 indicate turbo boost pressure was low or not detected.
  • Possible causes:
    • damaged MAP hose
    • low turbo boost
    • intake manifold or crossover tube hose leaks
    • damaged MAP sensor
    • damaged PCM
  • Inspect MAP sensor hose and manifolds for damage, leaks, restriction and misrouting.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 320,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #5 (permalink)
Old 02-06-2008, 09:17 AM
TurtleRacing's Avatar
TurtleRacing TurtleRacing is offline
PSD Addict
TurtleRacing is starting off with a positive reputation.
Have you done the UVC harness yet? If not, you might want to, mine did what you are describing a couple of times before it wouldn't run at all. i don't know about the code you are getting but the symptoms are familiar.
__________________
'02 F350 XLT 4x4 CrewCab Dually
JW Valve Body, HPX SS line,DP Tuner,6637,CCV,Zoodad, Foil Delete, Rhino Lined,TurboMaster WG actuator,203 Tstat & Billet Housing,Pyro,Boost & Tranny Temp/Isspros on the Pillar w/Glow PLug LED, MKO 5" Turbo Back,
www.turtleracingproducts.com
  #6 (permalink)
Old 02-06-2008, 02:01 PM
Please tell me more about uvc harness
  #7 (permalink)
Old 02-06-2008, 02:11 PM
PSD Addict
There is a wiring harness under your valve cover that feeds your GP's and injectors,, the clip that holds the connector weakens allowing the connector to seperate and loose contact. Now don't ask me how it regains contact sometimes, but it does cause mine came and went several times. You have to remove your valve covers and put a wedge in the clip.
Check this out;
http://www.ford-trucks.com/forums/27...or-wiring.html
http://www.forddoctorsdts.com/articl...icle-05-10.php
__________________
  #8 (permalink)
Old 02-06-2008, 02:36 PM
When it starts running rough. Go up and unplug one side of the harness from one of the valve covers. If it doesn't start running rougher, that's your problem side. If it does, replug it in and unplug the other side. If it doesn't run any rougher, then that's your problem. If it does, your back to square one!
__________________
Matt
1999.5 F350 CC
Tags
2001 , 73 , connector , f250 , f350 , ford , harness , p1247 , p1248 , powerstroke , uvc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
