You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Is it normal for a 10 year old block heater to trip a GFCI outlet that is on the same ciruct as many others within 6 sec of pluging in when it is -15F.
Yes. Find a plug all by itself for it. Don't run an extension cord if possible. If you must, run a heavy and as short as possible one. If it still trips then it is probably shorted and needs replacing.
__________________
62 Falcon 2dr
63 Ranchero
01 Saturn SC1 plastic Vega
11 Kia Forte 5
3 Bikes
I run a 12 amp pump regularlly from a GFCI outside, works fine.
I've had cords that had just a bit of water in them trip GFCIs. I would first try another cord, and if it still trips, then the cord going to the block heater on he truck is probably shot.
Had a GFI in my kitchen with nothing pluged in. Wouldn't reset. Finally pushed REAL hard on the reset button and it reset and then stuff replugged and then all worked fine - FWIW
