02-06-2008, 09:01 PM
I don't remember if you have EFI or not. If not, follow the fuel line away from the carb, until you get to something with wires on it. bypass the fuel line around it, leaving the fuel switch on "gas", and test drive it. In hind sight, you probably have EFI. This would mean the switch on the dash probably controls a relay,in series with the fuel pump relay, to shut down the fuel pump on propane. If you can find the relay, and remove it from the circut, you will be able to test as above. Of course, this will not check any other wiring in the pump cct. or the pump itself
